hah nah yhe panel gap specialists found that the two rear quarters have been resprayed. but not removed.
just a tape job
Did you assess the damage on the S15? I would say yours is mint in comparison :P
hahaha nah didnt get that far into it.
so does that next route sound goood?
wollombi-broke-putty-singleton- back way to maitland?
avoids boring hwys
Yeah i think its a top idea mate! Happy to come scout it and do pics etc with ya soon! Will make it a decent cruise for sure :yes:
Haha well use Street View etc so people recognise the locations! Probably attract some new faces so it would be handy for them!
Also, have to arrange Central Coast and Sydney people meet points AND will have to make contact with our Port Mac guy and see if he wants to join in the fun :yes:
yeah sounds good. we can sort all that out with google maps :)
Sweet! Well we should make a start on it so its all done and we have plenty of time for people to plan ahead :yes:
Also so tyres and fuel pumps can be repaired :ph34r:
always!
got stuck doing a training course all weekend for the RFS.
i would have been there otherwise
Sweet! Well keep an eye on the events section for it (Once Jarrad makes a thread :P )
I'm tracking down to Newcastle on Friday - Sunday. Red R34 GTT (VIC Plates). Hopefully I spot some other Skylines around :)
(Lived most my life in Newcastle)
Sweet, will keep an eye out for you! Be careful around Newcastle itself if your car is modified, the boys in blue had ruined the car scene up here due to the minority that spoilt it for all of us!
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
