Nah nothing's up man
Put go kart together
Hillclimb
New axle and springs in boat trailer so it will make the trip north at Xmas
Fit radio and whatever else I need to boat to make it sea worthy
Xmas parties
Track day for go kart at Wakefield
Fix axle seal in Melisa's car
Fix skyline and service
And want to try and get house painted as well
Just a few things to do
pretty quick!
benji theres a socket you can get that makes that a 2 minute job. a socket with a cut up it so the wire doesnt get tangled
yes used that socket but ABS booster is in the road and the heat shield for the manifold. Had to use a hole heap of extensions and joints lolz.
ended up having to take off my strut brace to screw new one in (I hand screwed it in as didn't want to risk cross-threading).
I will keep an eye on any beers (if its an open invite :) )
My car is off to Nathan @ Newcastle Dyno tomorrow for a tune and boost controller! Not expecting numbers much different than standard but hoping to get a mid range improvement.
Have you got adjustable cam gears? they beef up the midrange quite alot, they did for mine anyways.
Only mods are -7's, xforce dumps (I was told this is helpful when changing turbos), upgraded fuel pump and splitfire coilpacks (prob don't count as a mod).
It doesn't feel as responsive since the turbo changes and I am concerned about running these with standard ECU and boost control. The only reason I have made any changes was due to the possible failure of the ceramic turbos and everything else has kind of flowed on.
It is getting a PFC and Greddy profec-b tomorrow.
After this I plan on keeping it as stock as possible, well for a while at least :)
Edited boost control reference
Edited by djrobertshaw
haha yeah, probably should have explained that.............I know the standard boost solenoid does its job, but keen on running a low boost and hi boost with appropriate tune.
I may have been misled but a few people have said running -7's can see boost spikes with standard ECU and solenoid.............and its a neat excuse for the wife anyways!
The only things i would have added to that list is injectors and cam gears, the cam gears should improve response (only if its tuned properly aswell etc)... with the above you should be able to get 300+ kw at all 4 i would think...
your injectors (if there stok) will probably limit you to around 260ish and stop you from making best use out of the nice turbos you now have :)
hope that helps, although sounds like it may be a little bit late if its going in tomorrow.
Thanks for the advice.
I did consider making more changes but budget and trying to figure out what my plan is means that a couple of small changes now and then probably wait for the inevitable bang before doing more.
On a side note I am looking to change the color of the BBS LM rims, do you guys have an experience with anyone locally? I may just do it myself but if there is someone good then lazyness will prevail.
Nathan does great work
Rims are something you can do yourself but would be better left to the pros
Paint is one thing you get what you pay for and if the finish isn't spot on it will detract from the rest of the car
I can pay t but it is a 1-2 metre finish
That is it looks great till you get that close then you can see the minor blemishes
Is okay for racecar but not my car
Find the best painter you can afford wether it be a panel shop or bike repair/custom shop and get some quotes
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
