Sounds good mate! Hope the house is going well... We have been interstate a bit and off thrashing the car as often as we can :D
Ooh let me know how the new track goes :yes:
We are off to Wakefield again!
New track goes well, didn't realise the journo was there. I made the local paper
http://www.portstephensexaminer.com.au/story/2373368/gallery-no-hiccups-for-ringwood-hill-climb-event/
  • 3 weeks later...
Hey guys.. im having a dyno day on sunday at Heatherbrae.
https://www.facebook.com/events/526415517464770/
adress is 62 heather street heatherbrae, starts at 9am.
60$ for 3 runs and a BBQ with drinks.
10$ if you want to spectate and BBQ.
cheers
  • Like 1
  • 2 months later...
Hi Guys
Trying to find some E85 in Newcastle or some where closer to Forster.
Cheers
You can get United at Metford... There are 2 servos around that area with it! Probably your closest option...
  • Like 1
  • 1 month later...
Hey guys. I've inboxed a fe of you regarding an upcoming cruise/lunch.
For those who i havent and may be interested, it would be good to get a few local HUnter Valley/Newcastle/Central coast numbers together. Here is the link to the cruise:
  • Like 1
  • 3 months later...
Soooo anyone still alive in here? Just got my car running again would be good to have a meet up or something :)
Loooooooooooooooool! I havent seen this thread in a long while! :P
I think half of us are off getting married etc man haha
  • Like 1
5 months single after a 4 year relationship, band died off, skyline is main focus now haha. I'm keen for a cruise/meet.
This should have been the case from the start :P
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
