Yeah you gotta save your petrol for the snow ay ant?
Who thinks ant should drive the gtr to the snow and practice rallying?
He says he's not but I think he will.
Not overly.. just trying to limit the times i take the gtr to sydney.. ive got plenty on around then, and if i take it to sydney i would rather it be a biggish event (like offical SAUNSW stuff) or for a drive on good roads aorund there etc..
haha, no way im taking that down there.. + snowboards will not fit, and they aint going on the roof!
ok well... i guess we'll see you down here when it becomes "biggish" lol
Sorry mate, didnt mean to offend anyone.. just like to limit hwy kms i put on the car..
Would rather spend the time and effort developing more of a scene up here.. same way very little sydney guys would make the effort to come to something we organise up here etc which is understandable...
note to self,if planning meet or something with mat shall give him alternate time so he shows up when others do :yes: haha
Ya Kent!! :P This morning wasnt my fault, waited for 25mins at work to swap cars and then had to go to Dads house to get the damn thing as his missus was sick from a big night! Fail!
If I can be bothered I may drive down.
CBF with petrol though really :P
Thats cus Petrol sucks! You need some jungle juice :D
Yea i dont think i will be making it down to that one unfortunately.
I'm keen to see videos of this! DOOOOOOOOOOOOOO Eeeeeeeet!
Yeah why not, the wrc guys manage to do it without hitting anything...some of the time.
SOME of the time yes.....
WHY? If you flip you wont damage the paint, and while the car is on the boards you will save fuel :P
Hahaha you will see one or more of us man! It is a fair hike but ill be heading that way anyway ;)
Didnt know you owned an R32? What type of R32 is it?
BakedDildo!!!!!! :woot:
I dont own one, if you had read along the posts you would see its a new car to our Newy Crew, it'll be next door!
And its a GREEN one :whistling:
Your a clown -
Weight Reduction (Carpet and Spare Tire deleted from the boot, Floor Mats deleted for track days).
:laugh:
I've got a feeling I'll be putting a kitchen together on the 17th or at least putting stuff away when my wife tells me where to put things
Sounds sucktacular
I promise to drive up when a meet is organized up your way.... it's about time for some unity damnit! my only problem might be work commitments... other than that... I'm there.
And no offence taken Anthony, i actually found the irony funny :action-smiley-069:
Too easy mate..
i like catching up with the Sydney guys when going to events down there etc, but for me, its just along way to drive for what seems like more of a social event, thats all. that and im pretty flat out next month ha...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
