Be more than happy to have you guys join us.... An we'll try do the same, I guess we should probably look at a wisemans meet or something so there are twisty roads and it's central, but for now keep on the 17th ;) good to see so much action on SAU lately....
old pac then galston gorge?
im really keen to get a good cruise going on around here, the one out to wooten or whatever?.. everyone is abit busy over the next month arent they?
and maitland thing is on what 26th? are people keen to actually do this?
Last big run we did was old PAC, Galston gorge then Putty Rd, 2 tanks of fuel, cracked windscreen and paint hammered!!! Was awesome.... :D
August is stuffed mate, let's set a firm date in say 6 weeks or something?
Being difficult to annoy people is one of my goals in life.
Not to sure - should be fully tuned by then. I'll find out more next week.
I definatly can't make the 8/9, but you guys don't have to work around me. I'll prob be saying come for an impromtue cruise as soon the cars running anyway.
Edited by wedge_r34gtr
morning newcastle :P
yeah 8/9th might be a little better for me, got some family thing organised the weekend before i think?? cant remember if i forget about it ill come cruise :)
and matt BAKEDDILDO made me laugh so hard that my boss came out to see what the fuss was :P
Morning ya crazy kid...
Well we have a bit of time to make a decision, so once we get more feedback we can :D
I know right, Benji needs to put in a name change request...... But it needs to be BAKEDDILDO RACER now as he is a track warrior! :laugh:
Seeing as I've been busting my ass since Wednesday definitely.
But I cant do anything today or tomorrow :( busy and parents/ emmas parents coming up so need to entertain them.
Though will still be boozed hah
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
