Sounds like a nice list of parts
What turbo/s you going to run?
Come along on the 26th anyway doesn't matter what car we will only be doing the speed limit anyway
for the moment its going to stay stock turbos and ECU, dont have the cash to do the turbos and an ECU, i will be putting a set of HKS turbos in once i get some money and doing an ECU.
i dont have a car at all till i get the GTR back, she is daily driven :D if all goes weill i can pick her up on the 25th and go on the 26th tho, block is appart and being done as we speak, i totaly destroyed the 3rd and 5th bearing :whistling:
... block is appart and being done as we speak, i totaly destroyed the 3rd and 5th bearing :whistling:
Now me and the mad sceitist have to pull apart the block...sorry couldn't help it.
Its kind of a like a expensive safety feature with these cars...you'll get oil starvation and destroy the engine long before you loose grip...i still would have liked to see a larger sump on this build list for added protetion, but just make sure you overfill it by a 1L.
Also, make sure your builder cleans and checks everything throughly...you don't want to be pulling it apart again in 3 months cause of the bearing shavings floatin around in your block have destroyed the rings or something else....
Damn, thats pretty quick... cruise on 26th if you can make it...i don't think mine will tuned by then, but i might see if i can jump in with someone.
Sounds like a good plan
Motor should be well and truly run in after a cruise, just don't do to many freeway miles at first as the freeway and fresh bores are mortal enemies
LMFAO thats gold.
I dont have the cash for the sump and NItto pump could only do 1 or the other, im going to be using a stock oil pump with a set of reimax gears in her, the ballfes should deal with the oil starvation issue at hand with the restrictor in the head, its going to be my daily till i pay it off (1-2) yrs and after that ill do the sump and big oil pump and turn her into a monster.
From all the shops i have spoken to they all seem to think i will be fine with the OEM pump and gears as long as im not reving out to 10k rpm or anything crazy like that constantly. Ill be doing the 1L overfill also, btw what oil do you guys find to be the best for the GTR?
Edited by T4NK
Hey guys, for those of you that dont know.... My clutch is now toast :P Didnt think it would last long at the power level considering it was way outside its happy zone!
Should have been double clutching not granny shifting :D
ANYWAY, that puts my car out of contention for the 26th as Jim Berry will be working his magic on my clutch around then.....
Ill still probably jump in with someone tho, CHOOKIE???? :woot:
LMFAO thats gold.
yeah fair enough - should be all good
redline is the best, but you can only buy that in drums. Royal Purple or Motul 300V fully synthetic are the other great alternatives. 10-40w should be good for a daily driver.
lol...i was sort of wondering how long your clutch would last. Don't get me wrong - it still sucks that you toasted it. JIM's fully monty clutch is magic - zero slip.
My clutch & new flywheel ahould be leaving JIM's today - its a little different as its its a dual carbon clutch - superlight and responsive, but you actually need to slip it to put enough heat into so it actually grabs whens cold. It was a bit of a prick to get up steep driveways etc when the car was cold - JIM's almost doulbled the clamping force, so hoperfully it will be much better.
Yeah it was going to have a limited life which we knew from the start, makes me wonder if it has been slipping during the tune etc? Will find out i guess!
Mine is a sort of custom setup too, he said it'll be better than the full monty :D he was saying he does a bit of work for Paul.... Didnt realise he was meaning yours lol
The clamping force on mine will double over the Excedy button which should be pretty impressive! He said the heavy flywheel was the way to go for me, why did you go light?
my car's penciled in at JEZ's for a tune next friday, and cold start saturday...so at this stage i will be making the cruise if all my parts arrive and theres no hipcups etc My biggest concern atm is my injectors (only 600cc)...expecting to crack 400awkw (more hoping lol, just to say i cracked 400awkw - expecting more around 380 on finaly tune, i'm not going to be disappointed either way) so i should be pretty much at the limit for these injectors on paper.
so if everything works out, someone can jump in with me.
Dont you need a run in tune first? And 600cc? Really? :/
400 is a nice number ;) I will head there once i clear some debt, but mine will be RWKW for the skids! haha
that will be an impressive clutch lol - I actually didn't know i had carbon clutch till we pulled the engine out - was a nice suprice and explained the slippage. The hole clutch package (minus fly) only weighs like 3kg - much lighter then a normal twin. I just told JIM to machine me a billet fly wheel to match the clutch..so i don't know what i ended up with TBH.
I got the as part of a package deal from the US last year when i was going to do a -9 setup - brand new nismo MAF's, new injectos, midori modified intake pipe and nismo front pipe for $1200US - was pretty happy...although i sold the front pipes, not using the twin turbo pipe, going for a map tune (no mafs) and the injectors are probarly to small.
Whats this place. Ello peeps
ahh outsider :domokun: :domokun: :domokun: :domokun:
Edited by wedge_r34gtr
keep me posted mate if your offloading some parts, im going for a -9 setup so could be interested in some etc..
Yeah after a long long long conversation yesterday i learnt HEAPS about clutches and flywheels etc...... Lighter not always better, well rarely better in a lot of cars lol!
Dont run 600's man, you will only regret it and have to change it at a later date, do it right the first time :)
LOL, outsiders are OK, them wasteland boys bring the lulz :D
jim likes to talk clutch lol
...i'll make a decsion tonght. might see if i can pick some Id1000/2000 in sydney tomorrow
yeah only playin around..don't get to play in the wasteland that much due to NSFW...i'm basically on my work connection all the time atm :verymad:
You'll probably kill the diff or driveshafts next LOL
I'll have a spare seat but might be a tight squeeze in the back of the car, though driving chooks does sound like a better plan
Jelly
He does, awesome bloke to chat too!!
Yes big injectors! Doooo it!
Yeah I'm on at work or my phone, wasteland is awesome haha
Haha nah already did that with 250kw so it's all replaced :P
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
