I'm not sure yet
Would love to go but have a few things manned and don't think wok would let me have two long weekends in a row
I am going to try the Birthday thing on work as its my B'day on the 1st Nov :yes:
Lol you honestly want it?
Is it really that gross?
IF so, i NEED it :laugh:
yeah man im talking the november one, might have some gear like i use to have back, trying to slowly aquire it all back, along with a little pack horse to carry it
Motive will be asking for my help with it ;)
Well my car is out for the cruise Sunday now. Were still waiting on a few parts that won't arrive in time.
It's funny what you said about the ugly VCT cams...if you look at my sump you will notice a fitting that's not normally there on 26's...
Edited by wedge_r34gtr
So there is, on the right hand front at the top yeah?
What's it for?
Spill the beans man
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
    • M'kay....that's the one (single wire unit is just for dash temp gauge as you say) ; auxiliary air regulator is worth checking, and EFI relay of course.
