they be fine, got 12 rims at home with tyres so im not lacking rubber atm :P
probably wont have them done for sunday which sucks, rather not be forking out for another wheel alignment when im gunna have to do it again when coilovers come
Hmmm not sure, if i dont have the gearbox out that will be priority i think........... Depends how i go tomorrow night with moving cars around. I need to tow the rodeo out and put it in the right bay, take mine from the left bay and put it in the center bay (so i have 2 car spaces to pull stuff apart) and then we can service yours in the left bay.......... Freakin musical sheds!
Sorry Martin, dobbed you in........ Hope you dont mind............
http://www.skylinesaustralia.com/forums/topic/407632-tommy-kaira-25r/page__fromsearch__1
PS - If you do mind, COME AT ME BRO
Fffffffffffuuuuuuuuuuuuuuuuuuuu
Nah it's all good man
Replied to thread
Haha well i thought if anyone was going to be a guru it was going to be you............
Dunno bout being a guru
Someone asked me at the Charlestown meet
Them. Is it a real Tommy
Me. I suppose so how do you tell
Them. It will have a build plate on it somewhere
Me. Shrugs shoulders
Even if mine is a fake I still love it and wouldn't change except maybe for an R35
mat gunna do oil,filter,coolant tonight
makes it less hassle for you :)
got no problem doing them, never done my belts but guess ill learn haha
just dont over tighten right?
also probably wont get to do spark plugs dont have a socket long enough :(
Have you bled cooling systems before etc? If not, dont touch :)
Oil and filter is easy enough, just make sure the old filter seal comes off.
Belts are easy, and yeah do NOT overtighten them.... Make sure they have some deflection, if they are not freyed or too worn you can leave them for later too (up to you)....
Will make life easier in the shed of broken cars at the moment lolz :P
Exactly. i like martin's version.
Yep!
Subtle
Sexy
Smooth
And he has a nice car.................................. Wait.................................... Wha
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
