f**kin work
Up at 1.30 this morning to take a trailer to Sydney and start a training course at 5.00
On the way home now bur still s waste of time
Only good thing is this will boost the pay packet this week
Edited by m.j.h
Not huge just consistent kinda thing.
Our 2 meets have had 17 cars then 10
Yeah, there's a few Skylines up here but 80% of them aren't on this forum and think that forums are "gay"
Our import club meets usually have 10-15 cars mostly Supra's, Skylines and Silvia's
its basically the same people every cruise/meet tis good though, except when mat goes 4X4ing and gets lost kunce :D
probably keep growing the more we have regular meets too which will be good
then there's me and benji that rock up in commadores and say we own imports :ninja:
Are you working in the mines Sean? Get me a job next year when I get my trade?! :D
FIFO out of newy, 150k a year?
Hahaha
I've already got my trade but not sure if the mines are the way to go or not with all the talk of downturns in prices and the boom being over etc
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
