lol - it was regarding Ant's pods...
I had a question about them ...then i thought...I have 3 different intake boxes and a set of pods in my garage, I don't really need another intake lol.
ha probably a suitable amount then! i will be posting a for sale add tonight.. and probably tyres too as i just got some pics.
Hello look forward to seeing you again. :action-smiley-069:
Will be good to say G'day again :D
Maybe you should get a spare gearbox as well just in case
Yeah Jim said i need to learn to be mechanically sympathetic as the box is the next weakest link!
Got a HID kit being installed, come clear indicators and maybe a BOV. should be done end of month :D
Please NO BOV...... Clear indicators and HID are epic win though! :yes:
agree, stock gtr bovs to the job just fine!
Good for 400kw+ ive heard!! So please keep them and spend the money on useful upgrades :yes:
Be good to catch up for a cruise once i am back on the road.... My clutch will take 500km to bed it apparently so once its going i reckon thats a weekend lol
then skids on my stockies :D
Hahaha skids will be on the menu! On a private track of course!!
I'm not allowed to side step the clutch with this new thing :/ he said it makes gearbox go BOOM!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
