haha of course mat ;) and yeah dont want gearbox to go boom
if i pay for a membership on here say tonight would i get an email about nats entry?
or can someone give me an idea who it is i have to contact to ask this question as i dont want to miss out n im going to be pissed if i do
Send a PM to Shell and tell he thats what you are doing! I think you can download the forms from the NSW section somewhere........ It normally takes a while to get the membership sorted as they do it in their spare time!
yeah i found membership forms the other day, so basically pm her saying i wana be a member so i can get first dibs on a nats spot?
f**king dont wana miss out hey lol
you can join as a member at a texi day cant you?
might have to go for a drive mat
You better not take my spot you basterd :P There is only 50 spots on the track day :( I better get one so i can -
Gaters gonna gate!
f**kING LOL
i hope i dont take yours, i only want to do the track day, airstrip runs can EADC
also track day may suck if i hit speed limiter :*(
I wanna see how fast i can get the car in 800m! It goes off the clock pretty quick so who knows.... I think 245 is its current best!
And i wanna do the track day BUT spots are super limited by the sounds of it!
I want to hit the limiter :P And i dont have one lol
Upside down in turn one is the prediction!!!
Yeah it looks the goods eh? Pretty happy with it!! Cant wait to try it out thats for sure!
Yep, then it's time to sort out my tyre issues! Really hoping I can fit 285s! Will look very fat
And ill be very Jelly! Although it may be a bit expensive to fry them :P
If I had a gtr I'd get a hks bov cause they sound awesome, if I had money I'd get a hks BOV.
Haters Gunna hate :)
I don't hate BOV's as such but they will make your car run rich on decell and foul plugs etc
But they do make the bishes all wet, or so I'm told anyway
:no: your thinking of gate!!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
