I'm running Haltech :-) so +1 here too.
another great ecu to consider is the link/vipec. I was running one before the haltech and was really happy too (They make the speedo wave at you when you start the car too...just awesome.). Only changed to Haltech as the ecu was incorrectly blamed for a problem. the link G4 also allows you to keep the stock ECU case.
JEM LOVE Haltech :D So i got mine fully wired it as the GTT doesnt have a plug in option........ Spensive!!!
i just want my god dam car back...... have not seen it in 3 months let alone herd the soud of the RB and the veilside cannon, so depressing.
Whats the status of it??????
yep -
Optional - unplug and unbolt the ecu
There should be 4 philip head screws in the top of the case - undo them and take the lid off. You should be able to see the circut board
Edited by wedge_r34gtr
You wont need to pull the cables out as the ECU can stay in the car man..... That looks like it says Original Modified on the case in hand writing, which smells like a NISTUNE to me :D
yea fair enough, nice one.
do i need to remove the bracket the ecu is in? or does it pop/unbolt from that?
i do need to unbold the top to open it, so im going to have to remove it from the bracket yea?
The bracket should swing out of the way and you can get to the ECU or swing out out easy enough..... Just undo the screws, take the photo, post it and re-assemble mate :) As long as you dont mess with anything inside itll be sweet! No touchy touchy! (Keep that for J-Rad :P)
I cant remember if it was 2 or 3 bolts - I do remember it was pretty obvious what's holding in. Just undo all 3 and see if it comes loose.
i do remember the case itself should have 4 philips head screws holding the lid on.
As long as your gentle and you leave the harness and the ECU plugged in you cant hurt anything! Unless you go poking around inside the case which you wont :)
I remember thinking the quoted 6 weeks was pretty quick. Better they take there time and do it right though.
Mines been off the road since march if it makes you feel better lol
Mine is a daily atm, not going to buy a daily till i do the turbos and ECU and start going for 400KW at all 4, i have been told it should be ready 100% by next week. I have not had a car in close to 3 months and working in sydney and living on the coast sucks the wang when ur 6foot 4 and have to catch a farking train 5-6 days a week.
When u go to look at a GTR IMO u should get like 3-4 ppl to come along who own GTR's just so u look bad ass when u turn up with a convoy of GTR's tell the guy you need to make sure it passes the convoy inspection as its going to join it hahahah.
Edited by T4NK
Mine was 2 years if its a comp :woot: lol...........
Tsk Tsk oh Anthony I need to teach you how to work on cars.
The key is have a go, if you remember where the screws go your fine.
Sometimes getting in and having a go = broken shift knob.
S15 has been off the road for 60 days... and nothing has been done :woot:
and all I want is some BPU's installed
THIS!!!! LMAO
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
