Then go and do a top speed run in your car
There are never any oversize loads with police escort at those times either
The top speed is probably freeway speed man...... Stock az
yea fair enough, i still dont think i will be able to make it though unfortunately... i wont be back in newy untill around 4pm..
Bugger! Well if I can help I will, but I can't see me being of any use UNLESS I got mine running and swapped it with them but that's be a long shot
MWHAHAHAH start a war between the two that totaly destroys them both.
Love the idea. They did actually have a mini on air slanging match when they both turned up at the same house to do a story once
Maybe we should get someone to start a new news show and tell the real facts? Not sure how I'd look in a dress but I'll give it a crack :laugh:
Not really a news show but Media Watch try and The Chaser guys used to love ripping into TT
Where are those Chaser boys now? Haven't seen that for ages?
thanks matt.
i might have to ask if i can give gunnedah a miss at work... priorities right! plus i dont really need to go up there till friday, and i can fly up and back then...
sounds better to me!
They made a brief return for the election
One of them has a show on Foxtel and the others are doing a new show on Prime but not sure when it starts
EDIT.
Never mind got it wrong
Edited by m.j.h
thanks matt.
Sounds like a good plan....
EDIT.
Your all over it!!
http://forum.nistune.com/viewtopic.php?f=9&t=875
Pretty interesting! Looks like mine hey?..
Seems like I have a modified standard ecu with a daughter board fitted to be tunable?...
Mmm guessing no one would know how to tune it ha
Good find! I looked and had no luck but that is the board.... TBH if they don't have the software you should go Haltech.... If JEM say they can tune it then it's your choice... Would still be going haltech, but I am biased mate ;)
Yea im pretty keen on the haltech tbh, would like the car to run as good as possible, Just need to sort out timing with work etc. will forward the link to the guys and JEM tomorrow and see what they think and go from there.
I actually stumbled on that page whilst I was searching for haltechs wtf haha
I seriously looked even with the board number and still found nothing... You did well!
I would love to corrupt you to Haltech but just keen to see your before and after results for stage 1 :)
Yea as long as I can get off work, I think I will just go with the haltech hey...
Very keen to see the results, won't be anything fancy though... I think it will get me heaps keen to hurry up and do stage 2 haha
Wait until you talk to Adam and Dean.... They are mildly persuasive lol.... Oh and make sure you look out for Bobby, I reckon that R34 will be Aussies best :D you'll be in heaven
So guys, i am thinking the Ferry idea is out.................
We can still do old pac and Galston Gorge but we would need to turn around at some point and come back.
We could always aim to have Brekkie at Galston itself and then head on the return trip, there is 2 cafe's from what i can see, i am thinking that Rosies would be the go as there is a Franklins carpark accross the road and we probably wont fit in the carpark at Rosies so we could use the one at the shops, also looks like parking if you turn left at the roundabout but thats only a minor detail. Although the Ferry Rd was fun i am worried about the low cars and the GTR's
Ferry unload -
Steeper than the pic shows -
Twisty -
Ant, have you considered the HKS V-Cam System..
http://www.hks-power.co.jp/en/products/engine/rb26_vcam/index.html
Costs about $7,000 though (not including shipping from Japan)
And not including fitting And not including tuning.
Have you considered the request by most on SAU to STFU? Please? :blink:
fair call on the ferry.. im still happy to make a split meeting point for the people who want to go the ferry route?...
all that sounds good though mate.
no vcam for my car, can find areas to better spend money.
update on my ecu.. its basically been chipped by a company in japan that there is about 1 licence in aus to tune it haha.. so i will be going for the haltech :) and i got the ok to have work off too so very happy! my bank account wont be though.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
