FYI -
R34 GTR wuith aftermarket immoboliser in most cases still runs NATS which means you need to get the transponder programmed before the key will start the car.
R34 GT-T with aftermarket immoboliser does not need programming and you can get a key cut and it will just turn and start.
Thanks for the info, and welcome to Far North Newcastle :D
FYI -
Thanks heaps for that, going to get a key today then ill have it coded when i get the car back :D
well, some think planks of wood if no one has any propper ramps like the ones u use to get cars on the back of a trailer, use them to take out a heap of the angle off the ferry ramp
Martin was all over the planks of wood idea, the ramps are good but unless we get a stagea or a ute to come then they would be too long for all of our cars i reckon!
Not if they are short enough to sit in the boot.
Four short planks would be better than two longs ones and save a bit of time as well
I can still bring timbers and lots of them as well
But I like the idea of making a decision on the day
Well OK, lets go back to Plan A.... Ill set up the cruise including the Ferry based on your wood etc and THEN if we get any epically low cars on the cruise we will make the call on the day! Once again we can always split and meet back on Old Pac but would rather try keep the group together!
Happy to help.
I got one of my keys programmed by a mobile locksmith called Ultimate Lock in Sydney. It was around $100.
Cheaper than Hornsby Nissan. I received the same quote of ~ $180.
And not done by an apprentice ;)
hey man my wood is always good :3some:
Ok just bought the new key, will have it coded once i get the car back, then ill sort out the immobiliser, atleast ill have a spare key now :yes:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
