Item: OS Giken R3C Triple Plate Clutch for R32 and R33 Skylines/ GTR
Description: Used has done low km's still has plenty of meat left on it very nice street clutch for high power GTR's easy to use and super strong. Rated to 800hp +
Price: $1000+Postage
Contact: Ben on skylineben300@hotmail.com or PM
https://www.sau.com.au/forums/topic/402387-os-giken-triple-plate-clutch/
Would this work with my r33 gtst?
Got a rb26 and my twin plate alloy button clutch just shit itself
If so, what are the friction plates measuring at?
And how much for postage to 2326
Cheers
Cheers
Yes this will work on a R33 GTST i have put GTR clutches on Gtst before.
The Friction Plates measure: P1=5.25mm...... P2=5.25mm...... P3=5.20
Postage to 2326 = Approx $35.00 - $45.00
I might be crazy to ask but it's a push type right? Comes with throwout bearing and carrier? Willing to ship out of country? The friction discs look new but the plates look way heated. Rebuilt clutch?
Edited by NismoSTune
  • 3 months later...
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
