Started a thread a while back, but the layout got f**ked up and no moderator would help me, so i started a new one
This was my series 2 silhouette i owned for 4 years, which is now going to scrap metal
This is when i first seen it on carsales, i bought it off a turk from melbourne, he had a bum bag and left 2 points of speed in the boot
and also left oil out of the gearbox so an hour and a half outside of melbourne the gearbox didnt want to work anymore
when i got it rego'd
different grille
first wheels
So anyway i had a bit of a bingle, and it sat for over a year and i decided to strip it and send it to scrap
All going into this girl here, originally owned by fatz on the forum
heres a couple of pics
Specs on the car will be
R31 GTS1 number 164
Standard bilstein suspension, revalved to 90/10
Front and rear whiteline swaybars
Cazman adjustable caster rods
Adjustable panhard bar
R33 twin piston brakes with QFM pads
RB26/30 motor
HKS 272 cams, 10.08mm of lift
Race ported head
intake squish pads removed
HKS bronze valve guides
HKS valve springs
HKS adjustable cam gears
Nitto I-beam rods
Nitto/JE pistons
ARP main studs
ARP RB26 head studs
Nitto oil pump
Larger sump made by ariel at redstar fabrications
CPC new design plenum with billet throttle body to match
CPC billet fuel rail
All alloy cooler piping made by ariel at redstar fabrications
Ebay water to air intercooler
All pipework will be joined by pegasus clamps
Trust/greddy twin T67 manifold, work of art
Twin trust/kinugawa TD06's with surge ported front housings
HKS 60mm wastegate
2 speed powerglide adapted to RB with 5500 stall
B&M scatter shield
B&m pro ratchet shifter
yella terra flex plate
Will build a massive single piece tail shaft to go from the glide to the borgwarner diff
31 spline moser billet axles
Romac full spool
Bosch ID2000 injectors
Aeromotive A1000 pump inbuilt into an aeromotove 75 litre fuel cell
Turbosmart fp1200 fuel regulator
All steel hard lines for the fuel with braided lines in the bay
Link G4 plug and play for a gtr
Racepak digital dash
All i can think of for now, i have about 80% of the parts sitting there ready to go
Car is engineered and will be driven on the street all the time
will have more updates in next few days
Got some more pics, motor bits will be taken up to sydney in a few weeks to machine by gerg up above, he will put pics up as he is doing it im sure!
heres pics if the W2A dummied up in bay
looks like we will have to do some cutting to move the radiator forward and will have to run some thermo fans
and picking gts1 up tomorrow !
bit sad to see the old silo go, but gts1's are the bomb :)
+ as it's one of fatz', it'll be used to hard launches lol..
where are you getting the mani coated and how much is it?
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
