EOI at this stage but lets say $11,000 to take it home.
Car is engineered however is now defected as of 2 weeks ago.. :( can assist with the removal of defect however im selling as i just dont have time or room.
Engine:
RB25 series 2 motor (94,000Kms)
TD06/20g 8cm rear
Plazmaman Plenum
Plazmaman throttle body
Splitfire coilpacks
Big Injectors
BMI fuel Rail
Front Mount
52mm Radiator
Oil Cooler and relocation Kit
Tial 44mm External Gate
r33 clutch master
Catch can
3.5inch kakimoto exhaust
Custom Front/Dump pipe
Greddy Swirl Pot
Fuel Pressure Regulator with Gauge
Big Fuel Pump (unknown brand)
Interior:
Profec B Spec 2 controller
Adaptronic computer
Greddy turbo timer
Bride door trims
Autometer Phantom Boost gauge
Autometer Phantom Oil Temp gauge
Autometer Phantom Water Temp gauge
Pioneer MVH-8250BT head unit
6x9 in rear
Custom parcel shelf
6inch in the doors
4chan Amp in boot
Suspension/Driveline:
R33 LCA's
ISC N1 coilovers
Adjustable rear camber arms
Bolt in half cage
metal pinapples
mini spool locker diff
Exedy 100kg heavy duty clutch
Strut Braces front and rear
Hicas Removed completely (all lines)
R33 power steering pump
Hicas Lock bar in rear
Wheels/Tyres/Brakes
Varrstoen 2.2.1 (black)
18x9.5 +12 all round
235/45 all round
Slotted Rotors Front
Body:
Vertex Side skirts (sprayed by previous owner and is different colour)
Vertex Rear bar (sprayed by previous owner and is different colour)
Vertex Front bar (currently unpainted)
Genuine GTR front bar (sprayed by previous owner and is different colour) and has had N1 vents cut into it
Car was apparently resprayed 2 years ago?? (seriously bad job at that)
Windows tinted - Rear window all stuffed
there are some things to know about the car as below.
- rear CV's are effed (replacements to go with the car)
- defected 2 weeks ago for most of the stuff that is on the engineers certficate
- rego now due also
- bit of rust on the rear window
Car has also just had a new tune and made another 50wkw across mid range and is awesome fun to drive.
Edited by Frosty
