  • Replies 72
----IMPORNTANT NOTICE----
Guys there is a slight chance of rain Friday, the meet location isn't sheltted therefore if it does rain the meet location will be moved to Doncaster shoppingtown under cover car park, entrance via Doncaster road side, there are 3 ramps...take the middle ramp. otherwise if the weather is good we will stick with the current meet point in nunawading. Please check the thread Friday..I will update it no latter then 3pm Friday. Thanks guys hope to see some nice cars and some new people.
will still be there rain, hail or shine. having/had a couple of little things done on the car this week so will be fun to get it out on friday night. will keep an eye out for your confirmation on meet point friday mate
Edited by alkay
Depending on weather and how I'm feeling after work, I'll come along with the camera to take some snaps if anyone wants some.
Sounds good dude
Will update tomorrow wether or not it's the original meet point or not but at the moment we are still good to go for nunawading meet point. Keep an eye out tomorrow in the thread
CHANGED MEET LOCATION
weather is looking like it will rain later so dont want to run the risk of getting washed out. so meet location will be moved to under cover
instructions: take the doncaster road entrance, there are 3 ramps, left leading to roof top right leading to the bottom car park take the MIDDLE entrance.
still the same meet time 9:30pm for 10:30pm take off (pending weather holds out) please pass on the message. hope to see everyone there
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
