Hey all
Does anyone know if it's possible to register a car as a stripped car my four door r32 but is currently stripped and just a two seater and is bare metal on the inside I have originally planned
To use it just as a track car and buy another one for a daily but now it's not gunna work out that way so looking at getting the skyline re registered so I can get to and from work if anyone has any suggestions that'd b great cheers
https://www.sau.com.au/forums/topic/402537-rego-specs/
I wanted to do something similar in NSW and was told it would need to be engineered and registered as a 2 seater, i am assuming the ACT is similar... But i think the answer is YES its possible but not easy...
https://www.sau.com.au/forums/topic/402537-rego-specs/#findComment-6398956
Cool cool I Spose I should talk to an engineer then
If you have any modifications its probably a good idea before even attempting rego, i noticed your "car(s): NEORB25DET R32 4DOOR" so i would be assuming you would need that engineered for rego :)
https://www.sau.com.au/forums/topic/402537-rego-specs/#findComment-6399054
Dude your gunna need EVERY SINGLE THING thats not standard engineered on the car and your QLD "mod plate" dont mean shit to ACT rego unfortunately. I assume you have many mods and this is going to be expensive. Ray spence at canberra motor works is "The Best" and John Wilson AKZ is "The Cheapest".
https://www.sau.com.au/forums/topic/402537-rego-specs/#findComment-6399620
I spoke to Canberra connect today and they put me through to the pits who said QLD mod plates are fine in act they don't need to be redone hopefully that isn't different if I am trying to engineer extra stuff thanks for info on where to go though
https://www.sau.com.au/forums/topic/402537-rego-specs/#findComment-6399967
ok i'd take what canberra connect says with a grain of salt though the final say will be with the inspectors at dickson.. Sorry to be such a party pooper but i have taken two modified cars through dickson and its a trying process. GOOD LUCK !
Ray is very through though and his certs. make it easier at dickson.
https://www.sau.com.au/forums/topic/402537-rego-specs/#findComment-6402041
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
