Located on the sunshine coast
Specs:
Series 2 RB25DET Engine with only 70,000K's (plugs + coil packs included)
Nismo lightweight flywheel
Exedy heavy duty clutch only 5000k's old
Engine + Clutch + ECU - $1500
Please note: The water pump was cracked due to the incident so it will need to be replaced.
Gear box is on ebay to highest bidder
Click here ------------> RB25DET Gearbox
Rota 18 x 9.5 Alloy Wheels + Tyres - $SOLD
Custom 3" turbo back exhaust system with Stainless dump pipe, bored out cat, mandrel bends, custom made muffler. Low resonance and noise at cruising speeds, but loud when you floor it - $400
HKS Hiper D Coil overs - $600
New brake master cylinder with overhauled calipers all round, new pads and rotors, only 5000k's old - $Pending
Front and Rear strut braces - Offers
Immaculate interior - Offers
Greddy Profec B-spec II Electronic boost controller - $200
FET Automatic Turbo Timer - $50
Customer fibreglass subwoofer enclosure - $SOLD
Pod filter with Cold air box - $50
All prices are negotiable!
All items are sold AS IS, no warranties or returns
All other parts on the car are available for sale, just message me and let me know what you are after. I can post small items, but larger items will be collection only, unless you organise your own courier. If you need any pictures of anything just give me a shout
The engine has been tuned to run 7 - 10PSI, never over boosted, never revved beyond 2000rpm until completely warm, car had been a personal project and was 99% complete before it was crashed into, so i never got a chance to see what it could really do.
Edited by Smaz
  • Like 1
https://www.sau.com.au/forums/topic/402553-wrecking-1995-r33-gtst/
  • 1 month later...
  • 4 weeks later...
Some parts are still available but it wont let me edit this post, so there is a new one!
http://www.skylinesaustralia.com/forums/topic/409489-r33-rb25det-bits-and-pieces-series-15/
  • 2 months later...
Wat kinda condition are the coil overs in??
  • 3 weeks later...
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
