If anyone is interested and wants to come out for a drive I have hired the marulan on Saturday 18th August
If you have been to one of my days its very relaxed and everyone has a good time
The track is 3k to hire so I need 23 people at 130 to break even
Send me a pm if you want in
I'll cap the entrants at 25 so everyone gets as shitloadof track time
1 Peter
2 Jenna
3 hooks
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
Pete
https://www.sau.com.au/forums/topic/402558-marulan-saturday-18th-august/
  • Replies 238
Posted Images
Any cams or aaas licence will do
Helmet
Thats about it buti woul run a extinguisher if I were you
Josh blows cars up?
Should be good for this.
Will have to sort out money very shortly.
Will pm when I have payment ready.
Is it a drive down in the morning, drive home arvo thing?
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
