Just picked up my car today, Marulan is going to be so much fun with the new found power... Wow... :D
Hope I can avoid spins like mentioned above :)
  • Replies 238
Posted Images
If you have a boost controller you might want to turn it down. 1.5 BAR is a lot especially if you haven't gotten use to the power level.
My first outing in my GTR at about 280 AWKW I found that when you go in too hot / let off / blow offs kick all boost down / compression breaking kicks in violently + unsettled weight balance on the car = spin off the track. It's only recently that I find myself faster on high boost rather than just 1 BAR.
360 is a heck of a lot of power in a RWD car. Take it easy and learn to be smooth first, then apply the power. Of course you'll shoot down the straight like a bat outta hell!
Haha thanks guys (pezhead, fatz) the car is currently at 325-330 and is nuts... If I have to plumb back the gate I reckon the power will be 320ish and the tyres will be MUCH better so should be ok :)
Yea they will have to stuff a tree up my race cars exhaust to get it under theRe limit
Butt plugs all round eh? Lol....
What are you guys planning? Staying down that way etc?
I would plumb it back in for this track.
There is a noise limit at the track, and if they find themselves over, they pull the offending cars and find ways to quieten them down (As mentioned earlier)
Not running a screamer will help you immediately.
Yea myself and davo74 have a room with a extra bed if you like booze and cuddles
:blink:
Yeah the screamer is stupidly loud, it sounds awesome.... Buts its been designed as a 10min job to flip it back to plumbed back, quite clever!
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
