  • Replies 238
Posted Images
Club ones are up for rent but I won't be there cause GD2ILA's be'n a biach and won't let go of his harmonic balancer. Going for round two this weekend.
Can someone swing by my place tomorrow eve to pick them up?
Have a top day tomorrow all and happy birthday fatz if this is indeed a birthday track day for you.
I'll be 'enjoying' a full day of antenatal class tomorrow instead of smashing up Marulan. Yay.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
