  • Replies 238
Posted Images
hey pete, is this time trial or drift or mixed?
screamer pipe allowed?
just a friendly lap session, you can birng your timing gear if you want to.
as for the screamer pipe it might be over there noise limit, but the owner garry is really good and works with your car if it is.
last time we had 24 cars and 5 were over the limit ( all were fixed with some steal mess up the bum)
Seriously considering it.... May need to do some pads though!! When is the entry deadline??
do it, when we have 25 its full, currenlty we have 9 people
im pretty keen, hope to sort out payment etc soon fatz
ur details?
delails just pm me and ill send you bank details
Don't think so Matt, I'd bring a few Jerry's to be safe if I were you.
So finally we will get to see the car running huh? I'm hoping to have my WMI setup up and running by then, we'll see.
Yeah good idea... I can run on 98 if I need too...
Yep, should see it up and running after all this time!!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
