Hey guys just want some advice/ ideas on the following mods due to just moving to Vic an not knowing where to get things done.
So I have a 34 sedan gtt and wanting to do the suspension, I was going to go with just a good set of springs and shocks due to being told that coilovers are illegal in Vic. Any know any goo suspension shops in the west?
Also need to do the rest of my exhaust system and was wondering to either get the 3" dump with screamer pipe, 3" bellmouth dump, or 3" split dump?
Any ideas or suggestions greatly appreciated.
Rob :)
https://www.sau.com.au/forums/topic/402595-what-to-do/
Welcome to VIC.
They are legal, keep you ride height above 100mm and you're fine.
Rob :)
If you want to get raped by the noise authorities and do what you want.
Keep it quiet with a nice flow.
3" turbo back will do you fine.
https://www.sau.com.au/forums/topic/402595-what-to-do/#findComment-6400512
Ok just that I been told that coilovers are illegal due to being adjustable and affects the safety of the vehicle.
Not that I know of but if you want, stick to lowered springs and shocks for a peace of mind.
I already have 3" hi flow cat with full 3" system just need to sort out from turbo to cat
You mean to say you have a high flow cat and a 3" cat back exhaust...
https://www.sau.com.au/forums/topic/402595-what-to-do/#findComment-6400589
Coilovers are not illegal, Skylines come with coilovers standard. If you are referring to height adjustable coilovers they are also not illegal. What is illegal, is a ride height being < 100mm at the lowest point of the chassis (including exhaust system).
Screamer pipes on the other hand, are illegal. The legal limit is ~90db and the factory system comes in at ~87db, so almost any aftermarket system leaves you open to EPA defects.
https://www.sau.com.au/forums/topic/402595-what-to-do/#findComment-6400650
Awesome bud thanx for the info.... So bellmouth dump and springs will do for now.... Next question is do I keep on going with a 4 door project or upgrade to the big brother????
https://www.sau.com.au/forums/topic/402595-what-to-do/#findComment-6400783
Not true, adjustable coil overs that can lower the car below legal height are illegal (have only heard of one person being knocked back on an rwc for it) there is a thread or part of a thread on here some where about it, there are only two brands that are legal, i cant remember which ones they are.
That being said the chances of being defected for them on the road is extremely minimal.
https://www.sau.com.au/forums/topic/402595-what-to-do/#findComment-6401379
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
