hey guys,
I want to do an oil and oil filter change, but i haven't dont it before. I want to learn how to do it, and i've watched a few videos and it doesn't seem too hard at all. I have a 98' r34 GTT.
A few questions I do have is:
1. WHERE exactly is the filter located? Would i need to jack the car up or is it somewhere in the engine bay that I can easily locate? A photo of where it is in a r34 GTT would be great (I've searched around in the forum and google but couldnt find an answer)
2. WHAT is the best type of oil I could use? I went on the section in the forum reading "the goods on oils" but i dont really understand it. Also, one that isn't too expensive.
3. What type of oil filter do i need? One that I can readily get from a store like autobarn or supercheap auto or something, and not have to wait for delivery online, but also one that won't kill my engine lol.
Anyways, sorry for the noob questions, but I want to learn how to work on my car and everything. Thanks!
https://www.sau.com.au/forums/topic/402597-r34-gtt-oil-change/
Go to Supercheap, get Nulon 10W-40 fully synthetic (6L bottle) and a Ryco Z442 oil filter.
And if you havent already done it, I'd suggest you change your fuel filter too. Use a Ryco Z201 for this.
Edited by iwanta34gtr
thanks for the quick reply.
Just wondering where both the oil and fuel filters are located?
I think I know where the fuel filter is, but not 100% sure. I've attached a photo, is this the fuel filter?
http://img.photobucket.com/albums/v309/aznspec/filter.jpg
Edited by suwidji
Get yourself an good oil filter removal tool, I can't recommend a type (there are many different tools, hammering a screwdriver into the oil filter should always be a last resort) as I've never had to change a filter in the standard position on a skyline (I have a filter relocator).
As for oil, any semi-synthetic that is rated 5w-40, 10w40 that costs more than $25 that also isn't Magnatec. Try Gulf Western SynX 3000 ($20-$30ish, Repco is supposed to be cheapest). If you're willing to pay more, check Penrite HPR 10, Motul Turbolight 4100 (these 3 people have alot of success with and have positive feedback). Castrol Edge (just not magnatec!) is worth a mention too, Nulon not so much (my opinion is it's overpriced for a "full synthetic" which it actually isn't)
oh ok thanks, yeh i went to supercheap and it was pretty pricey for the Nulon one.
just a question regarding the fuel filter change, where is the fuel cap? I read that if i undo the cap, the pressure when removing the old filter will be a lot less and less fuel will come out.
Also, which one is the fuel pump fuse? I can't find the location in the fuse box.
This is what my fuse box looks like, not sure what to look for, but i didnt see anything that says fuel pump or similar.
http://img.photobucket.com/albums/v309/aznspec/fusebox.jpg
OH sorry, disregard the fuel cap question. I'm assuming its the cap you undo when filling petrol lol.
But which fuse is the one for the fuel pump?
I'm correct in needing to depressurize the fuel line first before replacing the filter right?
Edited by suwidji
worst oil advise ever!
i ran nulon for 1 oil change and it was shit
changed to gulf western sougi (now discontinued) which was awesome (ran about 30,000 kms on it)
now running GW synx 3000 (done maybe 20,000kms on that)
will change to GW synx 6000 when it needs changing next
so all in all, don't get nulon, go to Repco (apparently they stock it) and get Gulf Western Synx 6000/3000 (which ever one they have, the 6000 is the best but 3000 is still really really good)
oh, the Synx 3000 is only like $30 too so if you don't like how it feels, just change it out
autobarn does ususally
pretty sure someone in the oil thread said they got theirs really cheap from repco
and Birds said he stopped distributing GW because repco was under-cutting him
so sounds like either your repco is really small, or they are feeding you bs
google Gulf western distributers (your area) and grab it from them
I've tried finding the fuse in the fuse box, but im not sure which one it is- there's no "fuel pump" written on it.
Sorry I'm reall bad at finding out where things are in my car, but I'm trying to learn where everything is to better understand.
I've owned 7 GT-T's previously and used Nulon in literally all of them. Never experienced an issue. Although, never did track days.
For my own understanding - could you please elaborate as to what made Nulon a poor experience for you?
I have since started using Royal Purple in my GTR / S15's, however am still curious.
Thanks.
Mainly the fact that they charge $60 for a group 3 synthetic (which is what the synx 3000 is)
but the main things i noticed what that the top end was quite noisy after about 5000kms, sougi which was the same price lasted till 10,000kms until there were any hints of noise/rattle
i was a bit worried about the noise (wasn't mega loud like the lifters/tappets on my r31) but after changing the oil it was a lot better
i guess nulon is ok but its overpriced for what it was
i'd also be a bit careful as some people have been reporting sludge issues with RP (mainly the yanks)
  • 3 months later...
^ there's a few tricks depending on what you have available. do you have any removal tools at home?
I had one of the ones where it has a rubber strap & handle which worked fine when I had my GTt (long time ago now)
anything that can wrap around the filter & create leverage should do the trick.
as an eg. the same tool I had for my GTtwouldn't fit in my v36 due to the tight (ie non-existent) work-space, real pita & almost impossible to loosen by hand alone so I improvised using an old metal bar & strap that was lying around the garage
I would then loop the strap over the filter & wrap it up until the metal bar was tight against the filter using the ratchet wrench in the above pic. Once it was all tight against the filter the wrench acted like a lever bar to let me loosen the filter
    • Holy hell! That is absolutely stunning! Great work!!!
