I'm chasing the following R33 GTR parts
Main things i need straight away are the tailshaft and gearbox crossmember and speedo sender I fitted a gtr box on my r33 will drive it 2wheel until I can get all the other parts and enable 4wd
r33 gtr tailshaft and prop shaft,
gearbox crossmember
r33-r34 gtr/gts4 speedo sender
r33 gtr engine cross member + lower control arms + front sway
front hubs
front drive shafts
gtr sump
R33-34
attessa pump
abs unit
abs electric controller
attessa controller
rear diff
pm or reply for any of these bits and peices with a price
I'm located on the gold coast and can pickup within a 300km radius or organise frieght/post depending on the size of the item
https://www.sau.com.au/forums/topic/402601-r33-gtr-parts-wanted/
You can't mix and match. R33 and R34 are very different - dfifferent Atessas and different diff ratios ...R33 are 4.1 and R34 are 3.545:1 so you will also need speedo sende to match your diff ratio.
Good luck with your project!
