Ok guys just pickd up another r33 to be stripped n parted out, it has a light/medium front hit drivers headlight/drivers gaurd/bumper/ etc pretty mushed :P
1994 R33 skyline
Black paint
rb25det
5 Speed manual
jap 17's with good tyres
cat back exhaust
split dump pipe
will get more details, pics and price list up tomorrow selling everything
car is in South Australia (northern suburbs) might post smaller parts if i can find time
PM if chasng parts
  • Replies 53
ummmmm good question haha pm me a offer bud, i got $500 for rear brake set up on last one, $200 for diff n shafts, $100 for tailshaft
it has some aftermarket yellow struts in the rear havent had a close look yet
any suggestions on making it roll if you buy the lot haha?
will take a heap of pics today and list parts with prices, this car is complete going to do compression test but i may sell my series 2 package from my last wreck
either way i will have a rb25 engine/clutch/box loom ecu afm set up forsale (turbo maybe included)
couple pics for now....
ok done compression test and it the same as my other s2 package but this one has a heavy duty clutch and spirfires so with the other engine package already out its up for sale :P
RB25det engine/loom/ecu/afm 5 Speed gearbox, has no turbo in it but can sell with the turbo off this series 1 will confirm turbo spec later) car has 120K km's and compression was around 160psi through all cylinders drove nice n smooth oil looked fresh and has smurf blood in gearbox :P $2000o.n.o
great condition tailights $150 pair
great condition doors $100 each
seats drivers has wear hole in bolster all others look great $150 for all
old skool jap carrozzera (spelling? its jap pioneer) cd player with seperate pop out tv. fit dbl din offers?
dash surrounds looks good needs a clean $100
centre concole with lid hinge is good nick the lil plastic lock does lock perfectly $80
gearboot/plastic surround with ashtry (ashtray inside has been cut out had boost controller hiding inside) $50
Dash cluster 102***Km's everything seems to work $140
passenger s1 bumper indicator peice (has had some platic cut off back to fit cooler) $30
Brakes front and rear (rear with handbrake cables lca's) $800
Tailshaft $150
Half shafts $150 pair
ABS diff $100
Drift boot lip with boot mint condition (lock seperate) $250
complete Boot carpets with spare wood cover $100
2 piece Jap 17x8 17x9 (guessing size will take rims off n confirm brad/size) rims with decent tyres $800o.n.o
heaps of other stuff will pull parts off as ppl buy them :P
pm with with and questions
ok guys just bought a part so need to sell bits asap
lip spoiler/steering wheel/ strut brace SOLD
send me offers guys prefer local pickup as dont have the time to send
Brakes $750 complete or $500 rear (thats complete hubs handbrake cables lca's) $350 front discs n calipers
Tail lights $80 pair
Diff $80
Half Shafts $100 pair
Tail shaft $100
Seats complete front and rears (drivers has hole in bolster) $150
Tanabe 3 or 3 1/2" cat back sounds really nice $280
passenger headlight foggy but not broken bkt $50
stock grill with 'S' $20
centre console hinge good needs a good whack to shut but stays closed $50
Dash surround $60
Cluster $80
Boot trim complete $60
17 x8 17 x9 WEDS racing rims with decent tyres $400
steering rack $80
stainless split dump $60
stock turbo with lines mani $350 (appears to be s2 will dbl check)
window regs $60 each side
carrozzera jap cd player and pop out t.v $100 (its so cool it has ariels in the boot that attach to the rear window)
s2 rb25 running gear package $1700 engine/clutch/box/loom/ecu/afm
nearly everything is still here come get it!!!!
Hey mate interested in the diff and front LCA's what is your best price delivered to Newcastle nsw. You can keep the diff center and shafts if you want.
Cheers
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
