  • Replies 53
Hey mate, do you have the rubber grommet/bumper/stopper thingos that the bonnet sits on when you close it?
No sure what you'd call them but yeah, one on either side of the radiator, behind the headlights.
Mine are squashed as and squeak on the bonnet.
Cheers.
Rob.
Edited by Not a Pulsar
engine package SOLD
heaps of other parts here guys, will get into pulling this engine package out (not for sale) then want to gut the rest of it ready for the shell to go to someone who is going to use it for something awsome :P
Keep the pm's coming guys!!
$480 for rear brake set up complete with lca's handbrake cable etc OR $700 compltee rear with cradle diff half shafts :)
Front discs n calipers $320
Tailshaft $100
Steering rack $100
Seats front n rear $100
102k km dash cluster $80
Dash surround $40
Gearboot/surround $30
Digital climate control unit $50
Mint doors passenger complete $100, drivers no window reg/rail $70
Carpet $50
Mirrors $10 pair
Parcel shelf $40
Heaps of other stuff just pm me if your chasing something!!
$300 for front calipers and rotors
$200 for Tanabe cat back exhaust
$50 for split dump pipe
$200 for stock turbo with mani
Weds Racing old skool jap 2 piece rims 17x8 17x9 (need to dbl check) with pretty much brand new tyres $500
Steering rack $80
Half Shafts $100 pair
Diff $80
Rear brake set up with LCA's handbrake cables $450 (these will be used to move the shell but will be ready for pick up when moved)
Tailshaft $100
Great condition dash $100
digital climate control $40
stock intake mani/fuel rail/inj offer?
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
