  • Replies 53
seats SOLD
seat belts SOLD
diff and half shafts SOLD
door trims SOLD
Carpet SOLD
WAITING ON 'TYPEVU' TO GET BACK TO ME ABOUT THE SHELL ASAP!!!!! 0417080960
silver series 2 wing $40
hicas ECU $40
steering rack $70
Front brakes $300
rear brakes/lca's/handbrake cables $450
WED racing 2 piece wheels with great tyres $450
Tanabe cat back exhuast $220
stainless split dump $40
Stock turbo/mani $200
door locks/ignition still on column with key $100
passenger window reg/rail $60
drivers n pass central locking motors $40 each
Digital climate unit $40
stock seat belts $40
stock front castor rear/camber toe arms $50 the lot
heaps of crap here come get some :P
glovebox SOLD
centre dash vents SOLD
gearboot/surround SOLD
shell back up for sale due to no contact.....
slight/meduim front hit, be ok for tracker currently rolling with full rear brake set up, all stock suspension, hicas, straight doors, all glass fuel tank, boot, tail lights, bumper,$800
$400 no rear hub/brakes etc need it gone ASAP!!! may swap for aftermarket rb25 parts
ignition/door/boot locks and key $100
i am currently looking for fixed back seats/harness's hydro handbrake/ gauges/ etc etc
i have a cabinet full of r33 bits if something isnt listed please dont hesitate to ask!!!
Tail lights SOLD
headlight/indicator stalk SOLD
pass window switch SOLD
heater box SOLD
Handbrake mount/handle etc ON HOLD
Stainless top mount manifold heat wrapped $220
series 2 wing silver $40
abs unit $40
hicas ecu $40
power steer rack $60
pass window reg n rail $50
heaps of bits still here just ask
NEED SHELL GONE!!!!!
It comes with straight doors, straight rear quaters, all suspension arms and sway bars, that includes front lca's and 5 stud hubs (no struts/springs) full body loom, all windows they haven't been taken out, rear cradle with hicas, fuel tank.
Can negotiate other bits I have taken off to go with it.
Will take trade for parts, wheels/harness's/adj sus arms etc
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
