For sale this weekend i have the following.. Located in East Brisbane, May deliver in Brisbane only.
GTR Engine mounts Both left and right, Brand new - $100 each
GTR Center gauges - $150
High Mount manifold and gate for rb20/25 - $250
Some sort of gauges, Boost, Water temp and Oil Press,Comes with all sensors except water temp. -$150
Apexi Gauges, 2xtemp gauges and Boost, all sensors included (water temp, oil temp and boost) - $300
R33 Side indicators, standard orange - $30
XF Throttle Body with new skyline TPS - $80
RB25DET Throttle Body - $30
35/40 0.63 rear, some shaft play - $400
RB25 Exedy Heavy duty clutch, some meat left - $200
R33 Custom boot install(a bit of MDF with a sub and amp that sits on the bottom of the boot where the spare wheel goes) not sure if sub or amp are good - $100
R33 Skyline front seats - $100 each
R33 Windscreen washer bottle, with motors - $50
All prices are ono as i want it gone this weekend as i go back to work on Monday and wont be home for awhile.
Can text photos if interested
Cheers
Josh - 0413 719 366
https://www.sau.com.au/forums/topic/402671-r33-skyline-bits/
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
