HI,
I have a Damaged R32 GTR that I am wrecking. I was going to fix it but I found a shell and transpalnted bits and pieces.
No motor, box or harness, most other parts are availible.
I am Located in Sydney, I can post items at buyers expence.
Plese let me know if you are after a part not listed i will take pics and post.
Fuel setup was on and up and runing for less than 3000ks befor I lost it and heres whats left:
Under car custom surg tank, Tank fits on drivers side under car near back seat. It has 3x -6 and 2x -8 weld on bungs, was bolted to floor via Nut serts.
Dash fittings: all earls swivel except for speed flow one way valve
-6 2x straight, 1x 45deg,
-8 2x straight, 3x 90deg, 1x 180deg, 1x coupler, 4x hose clamp ends, 1x adapter to fit 044, SpeedFlow one way valve fits 044 and has -8 end
Earls Auto-flex hose lenths are a min of of -6 1m 1.1m and -8 31cm, 32cm 48cm, 72cm 1.2m 1.3m
1x 044 pump
1x Golan -8 fuel filter http://www.golanprod...om/filters.html for info.
6x 660 Rochester Injectors.
Get it all for $800 lot.
I have a passenger rear passenger quater pannel that I got to fix the car $200.
Front seats $400/pair. Drivers seat has some cuts/rips on it.
2x AFM and Apexi air pods $120
Doors (just the door itself and window/motor mechanism) $200 each
Stock R32 GTR twin turbos with manifolds heat shields - were perfect when i pulled them off the car but have been sitting around so i would suggest rebuild. $150
Rear Diff $350
Front Windscreen $150
Rear windscreen $150
Quarter windows $50 each
Best to just ask what your looking for and make an offer.
I will add to the post tomorrow
https://www.sau.com.au/forums/topic/402696-wrecking-damaged-r32-gtr/
  • Replies 91
Hi,
Rear quater - to repair car, I can take pics of drivers one on car now if anyone wants.
Front Seats - drivers is a little bit hows it going.
Door cards $50 each please look at pics,
Under dash trim with fuse cover - has a little glue residue on left side $30
If any one is interestid in the canon it was from a R33 GTR nice sound $100.
Spiro
0414 509 399
HI,
Sorry guys I’m 4 months into a 6month licence suspension and I work all around Sydney so I’m living with public transport ill try my best to get back to everyone but pics will probably be on saturday unless I get home early.
Hi,
I am willing to seperate the fules setup. Injectors $250, 044 $150, Braided lines and fittings - over 5m off lines and 10+ ends for $300.
also here are some more bits.
HKS Boost gauge. $30
Bonnet Lip $60
Brake Master $80
Clutch Master $80
Center Din Gauges $60
Dash Cluster $120
Side mirrors $50 each
Side Kick pannels $20 each
Rear Wing $70
Stering wheel, No horn $40. for all the ppl who asked i just found it.
Door Seals with ALL clips, little rip where window rubs on outer side inner guide side good. $35 Each.
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
