HI,
I have a Damaged R32 GTR that I am wrecking. I was going to fix it but I found a shell and transpalnted bits and pieces.
No motor, box or harness, most other parts are availible.
I am Located in Sydney, I can post items at buyers expence.
Plese let me know if you are after a part not listed i will take pics and post.
Fuel setup was on and up and runing for less than 3000ks befor I lost it and heres whats left:
Under car custom surg tank, Tank fits on drivers side under car near back seat. It has 3x -6 and 2x -8 weld on bungs, was bolted to floor via Nut serts.
Dash fittings: all earls swivel except for speed flow one way valve
-6 2x straight, 1x 45deg,
-8 2x straight, 3x 90deg, 1x 180deg, 1x coupler, 4x hose clamp ends, 1x adapter to fit 044, SpeedFlow one way valve fits 044 and has -8 end
Earls Auto-flex hose lenths are a min of of -6 1m 1.1m and -8 31cm, 32cm 48cm, 72cm 1.2m 1.3m
1x 044 pump
1x Golan -8 fuel filter http://www.golanprod...om/filters.html for info.
6x 660 Rochester Injectors.
Get it all for $800 lot.
I have a passenger rear passenger quater pannel that I got to fix the car $200.
Front seats $400/pair. Drivers seat has some cuts/rips on it.
2x AFM and Apexi air pods $120
Doors (just the door itself and window/motor mechanism) $200 each
Stock R32 GTR twin turbos with manifolds heat shields - were perfect when i pulled them off the car but have been sitting around so i would suggest rebuild. $150
Rear Diff $350
Front Windscreen $150
Rear windscreen $150
Quarter windows $50 each
Best to just ask what your looking for and make an offer.
I will add to the post tomorrow
https://www.sau.com.au/forums/topic/402696-wrecking-damaged-r32-gtr/
  • Replies 91
Hi,
Rear quater - to repair car, I can take pics of drivers one on car now if anyone wants.
Front Seats - drivers is a little bit hows it going.
Door cards $50 each please look at pics,
Under dash trim with fuse cover - has a little glue residue on left side $30
If any one is interestid in the canon it was from a R33 GTR nice sound $100.
Spiro
0414 509 399
HI,
Sorry guys I’m 4 months into a 6month licence suspension and I work all around Sydney so I’m living with public transport ill try my best to get back to everyone but pics will probably be on saturday unless I get home early.
Hi,
I am willing to seperate the fules setup. Injectors $250, 044 $150, Braided lines and fittings - over 5m off lines and 10+ ends for $300.
also here are some more bits.
HKS Boost gauge. $30
Bonnet Lip $60
Brake Master $80
Clutch Master $80
Center Din Gauges $60
Dash Cluster $120
Side mirrors $50 each
Side Kick pannels $20 each
Rear Wing $70
Stering wheel, No horn $40. for all the ppl who asked i just found it.
Door Seals with ALL clips, little rip where window rubs on outer side inner guide side good. $35 Each.
