Wrecking Damaged R32 Gtr
  • Replies 91
HI,
Im back on to stripping the car.
So here are some more pics and prices
Rear Seat belts and buckles $80
Attesa 4wd pump – $120
Attesa 4wd reservoir $40
Peddles - $15 each or lot for $30
Charcoal canister $25
Power Stering canister $15 - sensor lead cut/missing
ABS pump - $80
Drivers side 1/4 glass with rubber $80
Passenger side 1/4 glass NO rubber $40
Dash - $80
A Pillar garnish - $60 pair - Drivers side has 3 holes from single guage pod. will suplly pod also.
Steering column plastic - 4 parts - 50
Boot rubber seal $ 40 Perfect condition
Door/window seals - $ 20 Each please look at pics
Centre vent - $40
Heater/blower/AC boxes - $20 each
Tail Lights - no covers $70 each
More stuff to add.
Rear Cradel Complete
Cradle/Sub frame
Diff (excellent condition)
Half shafts
5 stud hubs
Gtr calipers + pads
Disks
Handbrake assembly
Handbrake leads
Camber arms
Traction control arms
Lower control arms
Tailshaft
Hicas cancel bar
Sway Bar
$800
Great upgrade for a s13 180....
HI,
Parts still avalible
Fuel setup from page 1 - Price Drop - $700
Doors - Price Drop - $150
Stock R32 GTR twin turbos - no dump pipes - Price Drop - $100
Center Din Gauges Price Drop - $40
Boost Sender $25
Side mirrors $50 each
Door cards - Price Drop - $30
Under dash trim with fuse cover - has a little glue residue on left side Price Drop - $20
Front sway bars with links, brackets - Price Drop - $30
Side mirrors - Price Drop - $45
Side Kick pannels - Price Drop - $15
Boot lock liner top bit hard plastic linner. - Price Drop - $15
Driver side rear Seat belt and buckle $40
passenger side rear Seat belt buckle only $10
Attesa 4wd pump - Price Drop - $110
Attesa 4wd reservoir - Price Drop - $30
Peddles - Price Drop - $10 each or all for $25
Charcoal canister Price Drop - $20
Power Stering canister - Price Drop - $10 - sensor lead cut/missing
ABS pump - Price Drop - $60
Drivers side 1/4 glass with rubber - Price Drop - $60
Passenger side 1/4 glass NO rubber - Price Drop - $30
Dash - Price Drop - $60
A Pillar garnish - Price Drop - $50 - Drivers side has 3 holes from single guage pod. will suplly pod also.
Steering column plastic - Price Drop - $40
Boot rubber seal Perfect condition - Price Drop - $30
Centre vent- Price Drop - $30
Tail Lights - no covers - Price Drop - $60 each
Diff cradle complete $800
Accelerator cable - Price Drop - $25
Front Windscreen Moulds - both - Price Drop - $20
Petrol Flap and cap $20
Boot/Fuel leaver with plastic - $15
Rear windscreen wiper motor - $25
Internal roof lights $15 each
Foot rest - $10
Boost Solenoid Boost Valve Sensor $40
Gear stick rubber boots and ring - $25
Aircon controller $50
Boot hinge spring system - $25
Windscreen Wipers $10 each or all for $25
Recirculation pipe $10
Std blow off valves $40
Intercooler pipe left and right ends $25 for both
Glove box $20
Intercooler Brackets top and bottom - note top ones not in pic - not sure what the other ones are $30
Stock ECU $60
Attessa ECU $60
HIcas ECu $60
Stock amp $20
Rear windscreen demister controller box $15
Drivers Side Qtr pannel - Has a liitle rust, I will sand back, and give pics $200
Roof $150 pics to come.
Afew more to add later.
Thanks
Spiro
0414 509 399
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
