Got some parts coming off my car soon:
1. Power enterprise 850CC injectors
Side feed
near new, used for no more then 50kms
selling due to upgrade (rebuilt engine died in the ass, going bigger and better).
Comes with standard RB25 rail, nismo FPR and PE wiring harness.
$900 ono
2. Standard RB25 injectors
came with a spare head I purchased
comes in standard rail
$120 ono
3. "Freddy" (as I like to call them) Greddy style forward facing plenum
Looking to use another plenum on the new engine
suits standard throttle body
has been machined to sit true on the head, bolt it up and go!
$220 ono
4. Nismo Tilton twin plate silent type clutch
Push type
bought it used from Japan, haven't had the chance to use it myself (it's in the car, but haven't driven it).
If I recall the plates have around 3.5-4mm of meat on them.
I'm willing to swap for an OS Giken or ORC twin plate clutch + cash either way
$750 ono
5. EOI Garret GT3076R
.70 compressor housing .82 rear housing V band T3 flange external wastegate
Ball bearing
Barely used, less than 2000kms.
Don't really want to sell it, I'd rather swap for a GT3582R (GT3540) in similar specs and condition, T4 flange and V band.
All parts will be off the car next weekend, willing to ship at buyer expense.
I'm located in liverpool region, NSW.
Cheers,
Adam.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
