I have had my R33 GTR for about three month's, now i am looking at putting some mods into it. But i am not sure where to start?
It's my daily drive at the moment, and it essentially stock. It has some Pods and a after market ganador exhaust.
In a few week's i will be on holiday's and during that time off. I want to be working on my car.
But honestly, I am a bit overwhelemd with all the option's on what to do!
Can somebody just give me a list of things that I will need to get some respectable figures out of my GTR?
After doing as much research as i can, I have come to the conclusion that i need....
Turbo's - What ones do I buy? Single or stick with twins?
Fuel Pump - What one do i get? how many L?
Injectors - Again no idea?
Intercooler - Can i get something that just bolts into the stock mounts? Recommendation's?
Piping - Is it nessasry? Thoughts?
Apexi PowerFC - I heard alot of people still use these. Are there any alternative's? Anything better? Anything better value for money?
Boost Controller - Needed?
Is there anything I am missing?
I plan on installing all the mods myself. Is there anything I should be aware of?
https://www.sau.com.au/forums/topic/402755-stock-r33-gtr-where-do-i-start/
Turbo's Garrett -9's (twins) which are good for about 300-320kw with stock turbo-like response. If you want 330+, then Garrett -5's
Fuel Pump - Nismo drops straight in and is the least ammount of trouble (flows 400kw+)
Injectors - Sard 700's I believe are on special right now (444cc stockers will max out at about 310kw, with a pressure bump via a adjustable FPR maybe 325kw max), bigger injectors (1000cc+) need a new bigger fuel rail
Intercooler - Usually fine for up to 380kw
Piping - Is it nessasry? Nope, but good clamps are. Factory piping can help prevent shuffling etc which hardpipe kits can cause.
ECU - ECU selection should always be what your tuner is most comfortable with. Keep in mind ECUs that use the stock AFMs will max out at about 310kw. A pair of Nismo AFMs will set you back $700. If you are going over 320kw, you will find a MAP based ECU will end up cheaper as you won't need to buy AFMs (Apexi PFC D-Jetro, Haltech, Link, ViPec etc). The cheapest option is Nistune with a R32 GTR ECU (R33 GTR ecus aren't compatible with Nistune)
Boost Controller - With adjustable wastegate actuators, and using either a manual or electronic boost controller add afew psi to get you closer to your target.
Cheers moodles :)
Couple more question's though;
I believe I am still running stock coil packs, should i be looking at swapping them over?
Where is the best place to order all this stuff from?
What is the difference between using MAP vs AFM's? Is there any advantages over one or the other?
Is it possible to achieve 350kw, while still being a decent daily? ie good on fuel...(I am a optimist)
Whats the budget?
1. Put stock airbox on
2. Exhaust
3. PFC & a tune
That's a $2.5k-3k spent right there.
You should do more reading though, things like piping and intercooler stay as is... Plenty of threads covering it all.
Oh missed that bit. Should be ok as long as it's a true 3" (jap exhausts tend to have a restrictor in the middle so get it checked).
So then just a ECU/Tune which will be $1500 or there abouts. Change the fuel pump as well and be happy really.
Otherwise it's turbos out, and that alone will be a 3-4k adventure given the turbos themselves will cost $2200. Certainly worth changing them if you can afford.
Then you can make 300rwkw on stock injectors & AFMs. Otherwise you'll be stuck around 250rwkw with stock turbos. If you do change turbos you will also need a clutch as a stock one won't last @ 300rwkw forever.
Either way there is no way you are going to get near 350rwkw with $5000.
You need $8000-$10,000 as you'd also pay attention to brakes, full fluids service, injectors/AFM etc.
No problem! Will check the exhaust. From memory its a Ganador exhaust.
I take it its best just to talk to my tuner (which i don't have one yet..) and just get it done all through them? As there are a few used Power Fc's going on the forum's. I need to decide on what tuner to go to.
I thought once you replace turbo's you should swap out injectors, fuel pump and what ever else? I didn't know i could just take out the turbo's and still get decent gains...
Main reason i am wanting to change out the turbo's is due to hearing the stock turbo's go boom after the 100,000km mark. Being my car has a Vielside speedo, Who knows how many genuine km's are on it, it says it is on 103,xxx.
Considering i will have about a week and a bit off work, I was planning on installing everything myself. Installing the turbo's myself shouldn't be too difficult as long as they are just straight swaps correct?
If i can get 300rwkw without opening up the engine and just adding turbo's, I will be stoked! Thats still with all stock AFM's, fuel pump and injectors??
cam gears, boost controller ( get a good japanese one ), -9s turbos, front pipes ( the stock 33 dumps are good at that level but the a good set like the CES ones will give a bit more and since you'll be there any way), Z32 AFMs ( get the apex'i pod kit to suit ), 600cc+ injectors, nismo pump and a PFC then a tune
open up the out let of the stock manifolds when fitting turbos
this with 19-20psi will see you clear of 300rwkw
this is basiclly the setup I had on my R34 ( I had -7s, stock AFMs and airbox ) and on 19psi it it made 312rwkw
I dont think you did a lot of research...
Turbo's - What ones do I buy? Single or stick with twins? Turbos -7's or -9's you choose
Fuel Pump - What one do i get? how many L? Bosch 044/ DW 300
Injectors - Again no idea? ID 1000's idle better than Sard 700's they will fit in stock fuel rail
Intercooler - Can i get something that just bolts into the stock mounts? Recommendation's? Leave it
Piping - Is it nessasry? Thoughts? Good clamps
Apexi PowerFC - I heard alot of people still use these. Are there any alternative's? Anything better? Anything better value for money? A lot of options that you should search through
Boost Controller - Needed? Yes, Greddy profec b spec 2
After market front pipe
High flow cat
AFM's are fine
Dumps are fine
8k - 10k
All for 300kw
I have tried to do as much research as possible...started before i even bought the car. I think i have learnt alot, but still HEAPS more to learn, as you can tell by my noob questions ha ha.
8-10k is too much to put into it right now.
Thinking 5k at the moment..even still thats a bit much.
Looking for best bang for buck mods, I thought slapping on some turbo's with the nessasry support mods would be the best bang for buck. While keeping it a reliable daily.
Perhaps i was wrong and should just get a tune and keep it all stock :\
:wacko:
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
