got my rb25-30 motor to sell.
-has prescision endurotec cast pistons (not forged pistons)
-king bearings
-moly rings
- everything done ready to bolt into car ie, vct line, water gallery welded, block drilled and tapped for 2nd tensioner
- comes with tensioners and timing belt
- reconditioned rb25 oil pump
- head fully rebuilt
- bottomend bored 40thou oversize
- standard rods
- genuine nissan headgasket
- new rb25 headbolts
motor is assembled read to put in car hasnt been run
yeah i got receipts
has cam gears and vct thing that goes onto cam gear or whatever it is
doesnt come with coils
complete rocker covers to sump and has vct oil line with it
i have photos. havent put em on computer yet but will put em up tomorrow after i put em on computer
price is 2000 dollars if ya want it no less. dont be a idiot and try get it for less coz ya wont. if ya need to feel like ya got a good deal pretend were starting at $3000
no tossers. hate the bullshit
either pm or sms me for contact 0449 140 132
located brisbane northside
Edited by joe blo
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
