Hi,
Just thought I'd post this up. Just saw this car advertised on Gumtree:
http://www.gumtree.com.au/s-ad/west-beach/cars/1999-r34-nissan-skyline-coupe/1003492890
Thought I'd seen it somewhere before and did a bit of research. Turns out I have seen it somewhere before....
http://www.exportcar.jp/en/component/auctstat/?view=auctstatdetail&id=2o2tcgIu1aIJ4O
Must have driven it around the world backwards a couple of times.....
https://www.sau.com.au/forums/topic/402793-beware-of-this-car/
Lol oh lawd.
How the phuck does shit like that get into our country....
(ive seen this happen before when I backtraced an incident with a dealership in sydney).
and gunma....wouldnt be suprised if it had nuclear radiation readings as well.
Haven't bothered trying to contact the seller. What's that going to achiev? The authorities know that this sort of thing is going on all over the country and not just with imports and they're not doing anything about it. It is so hard to get away with in Japan now as well that if anyone believes that it mostly happens before the cars come here they're dreaming
There’s just way too many inconsistencies regarding ODO and i assume every Jap import is non-original KM's unless proven otherwise. Overall condition of the car is a way better indication as opposed to an odometer reading that can be so easily tampered with.
Even on or own doors - In NSW you are free to change ODO's with no notification or documentation supplied to the RTA to make this change in the KM's on the dash. They "advise" however you keep a record of when it was made and at how many km's in order to notify a future potential buyer... Which for someone dodgy trying to make a quick buck out of a more appealing vehicle I have a slight feeling its something that they will fail to mention
Edited by nomnomv8
yeah as above, it is good practice to assume that the majority of imports in this country have fake kms on the clock. i'm sure there are some genuine ones, but plenty aren't.
and it's only a scam if the person currently selling the car is the one who changed the odometer. if they bought the car from an importer with the 83,000kms on the clock, thinking they were genuine, then they are just another victim.
Not if this legal precedent catches on throughout Australia. Link; http://m.news.com.au/QLD/fi1617141.htm
That's a completely different scenario. They were claiming it was a different car to what it actually was.
But did they know it, or were they "victims"? That's the relevant point I'm making. How is thinking a car is a legitimate article, whether it be what it is or the kilometers on the dash any different? At one point in time it's been altered to be something it isn't.
As you stated, it is a different senario but the basic premise is the same.
Edited by Truffles
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
