Simota do a 4inch Pod filter. Dry type. Using it on my R33 with GT30. Good and not too expensive.
Personally would never use a foam filter on my cars. Plus i feel that any filter that needs oil to work properly doesnt have the greatest filter element to begin with.
(LOL! Two engine bay spam pics in 5 mins!)
Edited by gotRICE?
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6404919
Lol! Im bored.. Just moved to Perth and looking for work. So have nothing to do but watch the awesome Skylines roll past my place and spam SAU with hopefully, some good information :P
There are some FINE examples in this area!!
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6405016
Why do you run a foam filter in bikes that race in bull dust?
Why do they run foam filter in alot of off road buggies and 4x4s?
They are the best filtration vs flow out.
In saying this there is ALOT to do with the quality of oil used.
Some very very high quality paper filters can stop smaller particulate dust. a pod you can literally see through is as good as fly screen.
cue someones rant opposing...
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6405024
nice engine bay, looks simple and effective without any excess try hard additions :yes:
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6405035
Im not going to rant. I only stated my opinion :)
Everyone to their own on the filter subject. I feel that each person needs to make up their own mind. I base mine back to the old Filter test. The foam jobbies were the worst of the bunch for filtration, but made good power.
Edit: Cheers silverS2. Never been much of a showpony, just like it clean and simple. Never got around to stripping the blue cam covers. Wanted a gunmetal anodised look. Cars living under a cover back in Wellington now :(
Edited by gotRICE?
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6405040
I didnt mean you were going to rant, usually someone does but lol. And If your reffering to the hks mushroom type pods yes they are as useful as tits on a bull.
I have a unifilter oiled foam gizmo, wire cage inside, and its a cylinder about 140mm round and 160 long, i figure more surface area is better, each to their own but. my 10c :-)
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6405263
I run 4inch drift filter too.... Cheap and are actually rated to be in front of a turbo (I read that somewhere so could be BS)
My POS finally ran this arvo so technically I've run one of these :P
https://www.dropbox.com/s/vtja61s77kvub09/Video%2019-06-12%201%2008%2018%20PM.mov
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6406926
ive always been a bit wary of oiled air filters on airflow metered cars, if they are over oiled then it can cause problems, fully agree with using oiled air filters on 4WDs and off road bikes as the oil catches the fine dust. . . .but for road use, not needed
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6407029
This was a test carried out by zoom magazine a few years back! Was on their project cyborg fwd drag car, test was carried out on a dyno dynamics dyno
Standard - 132.7 KW
Pipercross - 132.8 - $399
BMC carbon - 132.9 - $649
Drift Stainless - 133.3 - $100
Driftbitz Stainless - 133.7 - $66
K&N - 133.9 - $110
BMC F1 - 134.1 - $160
SAAS - 134.6 - $30
Driftbitz carbon - 134.6 - $33
JR - 134.9 - $105
HKS superflow - 134.9 - $195
NO FILTER - 135.1 - $ummm FREE!!!
Apexi - 135.3 - $120 (but they used one with the Air Fuel Meter bracket attached instead of just the filter which they suspect lowered the reading though only slightly)
Trust Arinx -135.9 - $155
https://www.sau.com.au/forums/topic/402795-4-pod-filter/#findComment-6407350
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
