After parting out my Supercharged 350Z I narrowed down my search for a new car to 2 cars. A Maserati Gran Sport & a R34 GTR.
After a few test drives in a Gran Sport I decided that it wasn't for me, It drove nicely, handled well & sounded insane - but it was a bit too old man for my liking. Besides, I had wanted a GTR since I was a kid :D
I contacted a UK import company that had imported for a few friends before & we discussed my requirements.
  • White, Bayside or Black cars only
  • As stock as possible - no cages, ECU's or turbo upgrades
  • Less than 100K Km
After around a week of searching, my new R34 was found!
It was pretty much standard. The only mods were an Apexi exhaust & downpipe, white Nismo dials & Carbon Superior leather seat covers. The car had done around 110K KM but it had a full Japanese history book with it.
10 weeks later & it had arrived in the UK & was read to be collected.
Once it arrived in the UK, it was undersealed, an alarm/immobilizer was fitted & the wheels were refurbished in gloss black.
The first thing that I did was install the Pioneer head unit that I removed from my 350Z. The previous owner in Japan had removed it before auction - I had a 5 hour drive home with no music :dry:
I also installed a HKS turbo timer, because I'm lazy :P
I also had a few other parts off my Z that I wanted to install, the main ones were Bride Cuga seats. Unfortunatley, I needed the HL models for the GTR and the Z used the regular models so the rails wouldn't line up :(
Next I installed an Apexi filter kit, Baffled twin turbo pipe & the ARC oil & radiator caps also removed from my Z
Then I installed a HKS SSQV, polished fuse box cover, Nismo floor mats & a HKS gear knob
I also installed my HKS AFK V2 that was also removed from my Z :rolleyes:
I then got the car serviced. All fluids were changed along with the timing belt.
At this point I needed some new tyres & since I was planning on upgrading the wheels to 19s I decided to do that instead of just replacing my tyres :whistling: In hindsight, this was a mistake :(
I decided to go for 19x11 ET25 Volk Re30s after I was offered them at a cheap price. I had always planned for RE30s to be fitted, just not this wide. After mounting the tyres, I fitted them & they were rubbing against the suspension arms. Some 10MM spacers later & they were on :)
Over the winter I spent the money I had saved for parts on the following
Nismo S-Tune suspension
KTS Inter cooler hard pipe kit
HKS SPF intakes & hard pipes
Mac Audio Speakers
ARC Oil catch can
HKS Engine plaque
Carbon lip & diffuser
Tomei Ti Expreme exahsut
Decat pipe
HKS EVC 6 Boost Controller
Nismo smoked front & side indicators
I also fitted some footwell lighting - Not everyone will like it, but I do :P
After Christmas it was time to fit my suspension. Started with the rears, got the first shock in place & put the wheel back on but the Nismos are a bit thicker than stock & the wheel would not fit. Even with a 10mm spacer it still wouldn't fit :(
It was either change the coilovers to something a bit slimmer or change the wheels to something a bit narrower.
I chose to change the wheels & I went for a set of Varrstoen ES2.2.2. 19x9.5 ET12 with 10mm spacers to give me ET2. I also had them painted in midnight purple
Once they arrived, I got some new tyres mounted & fitted my Nismos
Then got my Tomei exhaust & decat fitted
Thats pretty much my first year of ownership.
As soon as I can shift the RE30s & a few other unwanted parts then I can start looking at my next batch of upgrades.
Next on my list is
  • HKS 272 Cams
  • Sard 800CC injectors
  • HKS 2860-5 turbos
  • Tomei fuel pump
  • Maf delete pipes
I also have a set of replica Nismo skirts & spats that I need painting & fitted, I also have a HKS Fcon Vpro Gold ready for fitting once I can afford the above bits
https://www.sau.com.au/forums/topic/402804-project-r34/
  • 2 months later...
Finally got my car back today after its 10 week holiday to 360 Motorsport.
It originally only went in to have an oil leak checked over but ended up having a few more bits done :whistling:
* Nismo Coilovers were replaced with HSD coilovers
* Cusco rear camber arms fitted
* Attain Hicas lock out bar fitted
* Spare rocker covers painted in HOK Wild Cherry with HOK cobalt blue base coat
* ARC Catch can had an 2 AN fittings welded onto it, rocker covers had AN fittings welded on & some braided hose
* Plenum, TT pipe & rear turbo pipe were polished
* Cusco CF front strut brace fitted
and then today I also fitted the Zealou5 Titanium bonnet stay :D
It will be going back in to 360 in a few weeks to have Tomei cams, HKS cam gears, fuel system, MAF delete pipes & either Garrett -5 or -7 turbos fitted & then off to Abbey for mapping :D
https://www.sau.com.au/forums/topic/402804-project-r34/#findComment-6524103
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
