  • Replies 168
oh no your kiddin right!
lots of towels and borry your misses hair dryer
No kidden..... Its almost dried up but left ugly marks on the door trim etc.... Must be acid rain in Tomago :/
But ran the car with the heater at 32 degrees and used a heap of chux etc, should be OK
Hope you had the air con on as well
Sucks to hear but must be something about industrial ares in general as my car gets a nasty film on it at work
i use to work at a steel works, similar to the old bhp up here.
my camry, oh man, poor thing ay.
after a week, my sparkling white car would be coated in caked on black muck, i literally had to scrub it off after a week! needless to say i drove the skyline to work about 5 times and washed it after haha.
Also will most likely be in a Silver VZ Commodore, as the corolla is at the panel beaters due to a dodgy windscreen install 6 yrs ago which has resulted in rust.
I don't know what's worse, a corolla or a bogandore....
Bring the import or GTFO! :P
Joel bro, cut the exhaust and the springs bro!!
Just take them off/out... And put steelies on the back!! :P
So far attendance is looking good for the 34's :yes:
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
