This may have been covered before but i need some clarification,
I have tomei cams 256 8.5lift, car has been tuned and ive been assured by tuner that the mixtures are fine and he showed me that that changing the mixture made no difference. Im ruling out vacum leaks cause it seems to behave under throttle, but at light throttle it wants to jerk and under 2000rpm it will be jerky if you dont put the hammer down.
is this just normal with these cams or are my injectors dripping?
With these cams will i foul up my plugs if im doing alot of slow off boost/idling style driving?
I noticed after a squirted it in second and came on full boost, then pulled up at drive way it was behaving itself , and just 5mins before it was stalling on me....
any thoughts?
https://www.sau.com.au/forums/topic/402821-tomei-cams-making-car-rough/
  • Replies 102
that doesn't sound right
longer duration cams will need a tad higher idle & not stoich at idle (maybe stoich is possible if RPM high enough).
Sounds like he hasn't set the throttle enrichment properly, time to find a new tuner.
Im getting tired of going thru tuners :verymad:
tonight it was going weird too, started hunting like the power fc was reset or somthing, then came good, also noticed a massive cloud of smoke after a squirt in second, was enough to fill the street up, thats the second time ive noticed this...
Take the drive down the coast to DVS JEZ
Get him to tune your car
Win win
I tell ya im getting so annoyed with tuners and not getting the results $$$ has been spend here...
Maybe when i go E85 ill just take the drive and give him a go, cant do any worse surely.. :whistling:
Can pretty much guarantee you'd end up happy if DVS JEZ tuned it, take a look at all the results from his tunes. I'd get him to tune my Z32 when its done, but i'm doing the unigroup tuning course and want to do it myself :P
gees thats like a 8hr drive, hope i get some kind of discount, and that it doesnt some how blow up on the dyno, cause dam thats a long long way to get home, :whistling:
id end up just torching the car like on Monster Garage, jess james style hahaha :yes:
Edited by SliverS2
Well we already established earlier you probably need to visit a better tuner...
Why don't you go to EFI, they are in QLD and have been doing good work
well at the risk of getting flamed, i did originally go to ERD for my dump and it ended up with a 4week wait, and not his fault he was very busy and i got impatient and decided to pick it up, anyway, the dump was rubbing on the body so it wasnt right, and no hanger to support it and i got the shits with the whole thing, now EFI is part of that workshop so should i really take it back there... ???? i dont know..
seems like a bad experience to me.
Who's your tuner? PM me if you do not wish to name him publicly.
I really dont know if this is my tuners fault, hes tuned many many high horsepower cars, one GTR on ignition DVD which put out 850HP and without proof i dont want to give him a bad name.. i think hes a good bloke, a tuner can only do what they can with what there given.
so is it the consensus that its the tuner??? im starting to think that the whole laggy turbo response could even be these cams, what do more extreme cams do? is it possible that i was mistakenly given more extreme cams that are causing massive duration??
my cas is brand new so maybe that just highlights the tune again, :wacko: every time i pull up at some traffic lights people thing im ready for a drag lol... pretty funny. its similar to victa bray's burn out chevvy haha rah rah rah rah cant complain when the hammer is down though, in second gear on a bar, the back end was wanting to turn 180 degrees, bit scary.
maybe i should just use it like a burn out car and forget street driving :domokun:
Edited by SliverS2
A second tuners opinion would be a good idea I think, regardless of how nice of a person the original tuner is. Different approach to tuning it might yield better results or might not, but you won't know until you take it elsewhere.
thats a good point, maybe they can just do a quick run and look at the maps , its hard to know who to trust with tuning, they all spin there stories, im thinking DVS is the go, seems to have alot of credit on these forums.
better be worth it or ill be bordering psycho lol... bring out a shot gun or somthing hahaha.
now ... lets tune this huh??? and do it right huh?? ill sit here with my bourbon and you tune that dam car haha
joking.. but seriously.. can only go thru so much $$$ with tuners or else ill just go for a SS Ute and forget it..
Edited by SliverS2
might consider seeing if EFI can give it a couple of runs and tell me if its a crap tune or not, shouldn't cost too much hopefully..
im getting the feeling and by the smell on idle and the big puff of smoke on WOT that maybe its a little too safe and too rich, the throttle is very jumpy too, could this even be related to ignition timing too advanced for cruising???
resembles a car with 10:1 compression or somting..your either engine braking or your taking off ...
Edited by SliverS2
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
