Boost In Neutral.
By DraftySquash · Posted
Success! battery voltage needle calibration is a bit off but oh well -
Cheers Lith! You're right, it's entirely possible that there's other reasons for the low compression. It's off to the shop soon, skipping borescoping etc and just getting it out and apart, we'll see what it looks like then.
Wanted to clean the film behind the triple gauge so the lights show through better. Progress so far…. -
Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
