ok so ever since I got the laurel Ive been curious about the auto head light function.
its on the stalk and theres what i assume is a light sensor on the passenger side of the top of the dash.
how ever when i put it onto auto only the drivers side head light comes on.
thought it might of been the stalk and since I had another one in better condition laying around I swapped it in on the weekend.
but it hasnt made any difference.
anyone know if there is some sort of control box or anythin for the auto lights? or what could be the problem?
its not a big problem as the headlights still work as normal, its just nice to be able to have the factory functions workin properly.
cheers
Danny
https://www.sau.com.au/forums/topic/402830-problem-with-auto-headlights-in-c33/
the sensor for the auto lights is on the drivers side, if you put your had over it in the day while on auto it should light up( dash and what ever is working).
sounds like bad wiring, maybe even at the sensor plug, could even be the sensor.
The auto headlights should slicker on and off as you driver under bridges, tunnels, etc. That's normal.
If its flickering on and off at night time driving under street lights, then your sensor is a dud.
The main sensor is the one on the driver's/right hand side, under the smoked lens. It MAY use the sensor on the left as well.
In theory it shouldn't in any way affect one headlight, it's just a 3-stage switch for the headlight circuit (off/running lights/headlights).
It'll just a bad plug or relay. Mine has a similar little glitch.
Cover the sensor on the dash with something (wallet/phone) (or do nothing at night time)
Turn ignition on, door closed, turn ignition off.
Your auto headlights should stay on until you open the door.
Turn the switch real slow, just in between off and auto, you'll notice one headlight (left) lights up. Also pull the stalk back for high beams, there's a sweet spot just in the middle, lights up left side only, pull the stalk back any further and it lights up both.
Also on super cold mornings, turning indicators on will sometimes make one or both headlights quickly turn off then back on again (bad earth on the steering column?)
Edited by Nic_A31
I had the same issue (one light working in auto) with cefiro no.2. Didn't end up fixing.
There is a brown box plugged into loom behind drivers headlight, think this has something to do with auto headlights and foggies ( maybe) current cef is missing this and foggies and auto headlights no worky.
It's ghey
my left light doesnt work at all tho on auto.
and no matter how light/dark it is outside, when on auto the drivers light only works.
ill have a sus to see if i can find anythin.
i know there is a random box in the engine bay near the drivers head light that ive nfi what it does. i assume it somethin with the lights.
any ideas? i think its green?
scratch that, they do turn off with the ignition :)
if its the tiny green box near the rad thats not it, should be a brown box bolted near the drivers side headlight support mounting.
if that brown box does do some thing with the auto lights it seems you dont have it ?
Edited by Dan_J
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
