hi all
i mentioned somewhere on here a while back i was going to build a trailer for my dirt circuit race car
so now its completed i took some happy snap's along the way
first desion was actually what requirments were needed and how big did i want it .
1 had to have electric brakes
2 had to have 4 inch drop axles so the trailer was lower to the ground
3 trailer had to tilt for easier loading and off loading
4 ramps had to be fitted to back of trailer so no crawling on ya hands and knees sliding ramps back in esp when it was dark and muddy .
5 led lights all around
6 did not want full floor just runners down each side for wheels to sit on & had to be alloy
7 mag wheels just cause i had some lol.
8 trailer bed had to be 4800mm long x 1980mm wide inside measurement so trailer would be on maxium size for total width.
ok that sounds easy ey lol well i had a partner in crime who happens to be a mechanicel engineer so his job was to draw it all up and well make sure it works lol .
he put together a list of materials required for the job not only that but had the correct measurement of every piece .so i emailed a list of all the cut size bits to the local steel supplier and got him to quote the materials .
the price he come back with was cheaper than i had worked out so we gave him the go ahead . next day a truck rolled up with a pile of metal all different sizes lenghs diameters i just looked at the pile and thought what the f........ ah well i was pretty good with a mechano set as a kid how hard can it be lol.
scaled picture in one hand and tape measure in the other work started lol first job lay out the main chassis and make it square post-23482-0-02762800-1339995519_thumb.jpg
by now my mate had come around and made life a bit easier put a few pieces together a few tack welds and started measuring cnr to cnr now i thought 3 or 4 mm out of squere was good enough but the look of horror on my mates face tells me maybe rough enough is not good enough his idea of squere is less than 1 mm so away we went adding more n bits tackibf them in remeasure with string lines tape measures and set squeres this was like maths class comming back to haunt me lol.time for another pic post-23482-0-02762800-1339995519_thumb.jpgpost-23482-0-11648400-1339995944_thumb.jpgpost-23482-0-85392900-1339995972_thumb.jpg
we had by this stage had the axles in place measuring several times to make sure ever thing would be aligned straight and true .post-23482-0-04677200-1340004456_thumb.jpg
next come more cross bracing and smaller supports for under the wheel runners . next we started on the draw bar this was another mm x mm experince lol we made the pivots so the trailer could tilt useing 25mm bright bar for the pins and a bush machined to fit the bush was welded in each side of the drawbar so brackets could be welded off the trailer frame and conected to the draw bar sorry no pics of that .
once we had the draw bar connected to the frame we went around welding everything up and flipping the frame over to do the underside also took to opertunity to undercoat the frame while it was off the ground kill rust undercoat was paint of chioce .post-23482-0-31418800-1340004813_thumb.jpgpost-23482-0-03009100-1340005054_thumb.jpg
once lowered and back on jackstands we got stuck into making the side rails and mount the mudgaurds and make the rear pull down ramps .
just before that tho we hooked it up to my old wagon and towed it out to the street to test the tilt side of things we discovered it tilted too good and in a later fix we resolved that problempost-23482-0-99092100-1340005073.jpg
so back into the shed where all the other bits and pieces slowly went together the pile of steel was getting smaller and smaller and my smile was getting bigger and bigger lol once we started mounting the floor it started to look like a trailerpost-23482-0-13528400-1340005354_thumb.jpgpost-23482-0-69887700-1340005386_thumb.jpg .
moving right along come the fun bits like mounting lights and hiding the wiring and wiring up the electric brakes give the old girl it's final coat of paint in this case it was killrust hammertone charcol grey gave it a good 3 or 4 coats just kept going till the paint ran out lol.post-23482-0-29086300-1340005593_thumb.jpgpost-23482-0-16975200-1340005581_thumb.jpgpost-23482-0-16975200-1340005581_thumb.jpgpost-23482-0-27549100-1340005566_thumb.jpg
trailer past inspection and now has 12 months rego with everything i wanted on it just waiting on some jerry can holders to add to it and my spare tyre to get mounted onto the other mag it's all done .
i could not have build this without my good mate travis so kudo's mate much apreciated :-) ah now we get to do it all again in a month or two as travis needs one for his race car ..this explains my absence for here for quite a while hope you enjoyed the read and pics
cheers dean
https://www.sau.com.au/forums/topic/402832-trailer-project/
how much tilt did you end up with?
how are you tilting it?
i have seen a trailers setup with a large bottle jack mounted between the A frame and the bed or if you wanted it all electric you could use a linear actuator but to be rated to safely lift that weight its going to cost a bit.
https://www.sau.com.au/forums/topic/402832-trailer-project/#findComment-6407759
  • the front of the trailer lifts about 14 inches there are drop down legs at the back of the trailer to limit the amount of tilt .
  • you just drive the car on slowly and the trailer tilts very gently and as you drive forward slowly the trailer slowly drops back down into position . no jacks no actuators just good ols mechanical leverage works a treat , as long as you just drive on slow and reverse back slow .ive built quite a few this way with no problems .
cheers dean
https://www.sau.com.au/forums/topic/402832-trailer-project/#findComment-6407920
Hey, great project. I am in the process of planning my trailer for the track car. I've got a large tandem that just ain't what I want.
So, maybe you can help out with a couple of questions:
1) How long is the deck from the pivot point? Does the whole car wheel base roll on to the trailer before it reaches the pivot point (so it doesn't tip prematurely)?
2) What do the mini-ramps do?
3) You mentioned you used drop axles? are they different to conventional axles? If they are different - do you have pics?
4) Is it possible to get a picture of the whole trailer setup side on (tipped)
5) Are the leaf springs individually mounted (not load sharing)
Thanks - in advance!
https://www.sau.com.au/forums/topic/402832-trailer-project/#findComment-6408400
will take some pics and measurments in the next day or so for you but i can awnswer a couple of your questions now
the drop axles instead of just been striaght the stbs are mounted 4 inches higher so the deck of the trailer sits lower to the ground .it uses just plain slipper type springs for n other reason to save a bit of cost plus never had a problem with them in the past.
the ramps pull down and when the car drives up on the ramps it pulls the front of the trailer up into the air .
depending on the car been loaded depends on if the whole car gets on the bed b4 it tilts down or not ....when driving the car up onto the tray and you feel the pivot point start to drop just inch the car forward and it drops really gently .
ive made quite a few of these over the yrs and never had any probs with them the oldest one would be 15 yrs now and still going strong. .
i will measure the bits you want tomorrow for you cheers dean
https://www.sau.com.au/forums/topic/402832-trailer-project/#findComment-6408464
That'd be fantastic.
do you have specs of the trailer bed and how it pivots off the drawbar?
https://www.sau.com.au/forums/topic/402832-trailer-project/#findComment-6408489
the trailer bed is made from 75 x 50 mm x 3mm thick rhs as are the main 2 runners down the centre the smaller cross braces are also 50 x75x 3 mm , the smaller diagonal braces are only 20 x 2.5 mm. the pivots are 25 mm agriculture pins cut down to size and a bush turned up for them to sit it they are welded into the draw bar/
the draw bar is 75 X 50 X 4 mm thick. the alloy floor is 2 2400mm X 1200mm x 3mm sheets cut long ways down the centre to become the runners for the floor . will try and take some pics now its out of the shed and do some close ups of the pivot points for you .
cheers dean
https://www.sau.com.au/forums/topic/402832-trailer-project/#findComment-6408928
used the trailer for the first time on the weekend tows like a treat at 100 ks no sway no rettles or squeks i checked a few times to make sure it was still there lol.
and to top it off the friver of the race car we was towing scored 2 wins and 3 seconds out of 5 races some of those from rear of field good day all round
https://www.sau.com.au/forums/topic/402832-trailer-project/#findComment-6414641
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
