Hey Peeps I have a bunch of R33 parts up for grabs,
I have for sale my Hypergear ATR28 G2 Highflow (R33) Turbo, no shaft play, only used for around 8000km's. Has made 235 rwkw @ 18psi on my R33 GTST with almost stock response.
Comes with HKS Adjustable Actuator (Set to 15psi), and braided oil line.
I also have a 3" JJR Bellmouth Dump/Front Pipe and Apexi Super Suction Kit Intake pipe (2.25" - 3.5")
The dump pipe has a O2 sensor attached (8000kms old) that I will throw in.
I will sell all 3 peices as a kit (Turbo, Dump and Intake) for $850
This will give you all you need for a good free flowing setup.
Or as single peices:
Turbo and HKS Actuator $700
Dump Pipe $100
Apexi Intake Pipe $150 These Intake kits are over 400 bux new
I will post up pics of the turbo with actuator tomorrow night
I also have Powdercoated RB25 Plenum and Crossover Pipe coated by Craved Coatings (SAU Member) Those of you that know Chris know how good his work is. They are coated in silver chrome to give them a polished look without the constant cleaning needed on polished parts. All cast marks have been removed and entirely smoothed out.
I am after $300 for both and I will throw in the BOV (Standard RB25) as it is still attached to the crosover pipe.
I also have a full R33 GTST S2 interior, Front Seats, Rear seats, Front Door Cards and Rear Cards up for grabs.
Drivers seat stitching is starting to come undone in the usual spot but not bad (will post up a detailed pic tomorrow) and front doors cards have a small hole in each for tweeters but generally in very good condition.
$400 for the whole lot.
All parts are in Hills area Sydney, will post at buyers expense but would prefer local pick up for the interior.
Pm me if you are interested and Ill get back to you ASAP.
Cheers
I'm also from the hills, I swear i've seen your car around! Now i know how immaculate it looks under the bonnet!
Will keep an eye out for you / any more parts that come up that i'd be intersted in.
:wave::thumbsup:
You probably have Colin, I have owned it for over 10 years.
The pics posted on here are the old setup, looks even better now :)
That's why I'm selling all this stuff, need to pay for more go fast bits
JJR Dump pipe sold - Thanks Matt
Apexi intake pipe back up for sale - wasn't what buyer was after
Powdercoated plenum and crossover pipe with bov still for sale
R33 series 2 full interior still for sale
Turbo and Intake sold
Still have powdercoated Plenum, Crossover Pipe and BOV up for sale as well as Series 2 Interior.
Come on peeps, buy my Sh1T! Nothing wrong with a bit of bling
  • 9 months later...
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
    • I made an extension of the item circled above in red that is hard wired to the battery and tucks away nicely in the engine bay, could easily do the same if it in the boot, just run the extended cable out under the bonnet or boot lid, I then just stick the charger on a milk crate to get it off the ground
    • It's purpose will be to stop the regulator plug from leaking oil. As GTS said, if it seals properly, it will mainly just have the effect of slightly higher oil pressure. I'll assume tolerances/fitment in the relief valve aren't that close that the washer being missing won't let it vent at 100% capacity too.
    • I put the charger in the engine bay and run the power cord down through one of the holes in the undertray, or at the back end of the engine bay, any time I need a car to be on a charger outside. In fact, I bring the extension cord up through into the engine bay so that it's not dragging around where it could get wet, or easily unplugged.
