Hey Peeps I have a bunch of R33 parts up for grabs,
I have for sale my Hypergear ATR28 G2 Highflow (R33) Turbo, no shaft play, only used for around 8000km's. Has made 235 rwkw @ 18psi on my R33 GTST with almost stock response.
Comes with HKS Adjustable Actuator (Set to 15psi), and braided oil line.
I also have a 3" JJR Bellmouth Dump/Front Pipe and Apexi Super Suction Kit Intake pipe (2.25" - 3.5")
The dump pipe has a O2 sensor attached (8000kms old) that I will throw in.
I will sell all 3 peices as a kit (Turbo, Dump and Intake) for $850
This will give you all you need for a good free flowing setup.
Or as single peices:
Turbo and HKS Actuator $700
Dump Pipe $100
Apexi Intake Pipe $150 These Intake kits are over 400 bux new
I will post up pics of the turbo with actuator tomorrow night
I also have Powdercoated RB25 Plenum and Crossover Pipe coated by Craved Coatings (SAU Member) Those of you that know Chris know how good his work is. They are coated in silver chrome to give them a polished look without the constant cleaning needed on polished parts. All cast marks have been removed and entirely smoothed out.
I am after $300 for both and I will throw in the BOV (Standard RB25) as it is still attached to the crosover pipe.
I also have a full R33 GTST S2 interior, Front Seats, Rear seats, Front Door Cards and Rear Cards up for grabs.
Drivers seat stitching is starting to come undone in the usual spot but not bad (will post up a detailed pic tomorrow) and front doors cards have a small hole in each for tweeters but generally in very good condition.
$400 for the whole lot.
All parts are in Hills area Sydney, will post at buyers expense but would prefer local pick up for the interior.
Pm me if you are interested and Ill get back to you ASAP.
Cheers
I'm also from the hills, I swear i've seen your car around! Now i know how immaculate it looks under the bonnet!
Will keep an eye out for you / any more parts that come up that i'd be intersted in.
:wave::thumbsup:
You probably have Colin, I have owned it for over 10 years.
The pics posted on here are the old setup, looks even better now :)
That's why I'm selling all this stuff, need to pay for more go fast bits
JJR Dump pipe sold - Thanks Matt
Apexi intake pipe back up for sale - wasn't what buyer was after
Powdercoated plenum and crossover pipe with bov still for sale
R33 series 2 full interior still for sale
Turbo and Intake sold
Still have powdercoated Plenum, Crossover Pipe and BOV up for sale as well as Series 2 Interior.
Come on peeps, buy my Sh1T! Nothing wrong with a bit of bling
  • 9 months later...
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
