Item: RE Audio XXX 6.5" components/splits
Item Condition: Brand New Condition (Used)
Reason for selling: Getting company car
Price: $500
Extra Info:
Complete with box/packaging as new,
Made in USA
Clean powdered by a Zapco 350.2 Amp
Impedance: 2 Ohms -
6.5" Midbass Driver with very high excursion
1" Silk Dome Tweeter
Power Handling: 150W RMS
Item: Zapco Ref 350 2-Channel Amplifier
Price: $700
Extra Info:
Hand made in USA
Complete with aluminum mounting brackets, box, manual, birth sheet. Including balanced Symbilink Cable & SLDIN SymbiLink Adapter. -No need for RCA’s
Stereo, 4 ohms: 2 x 100 Watts
Stereo, 2 ohms: 2 x 170 Watts
Bridged, 4 ohms: 1 x 330 Watts
T.H.D. + Noise: <0.025% @ 4 ohms.
- Hand made in USA
-Total power output 380 Watt
-SymbiLink™ Balanced Inputs
-RCA Unbalanced Inputs
-Two Ohm Stereo Stable
-18 dB Variable Bass Boost Control
-Built in Variable Electronic Crossover
-Bridgeable
-Three Channel Capable
-High Current Bipolar Outputs
-Optically Isolated MOSFET Power Supply”H
Item: Zapco Ref 1100.1 – Mono Block Amplifier
Price: $900
Extra Info:
Hand made in USA
Stereo, 4 ohms: 1 x 825 Watts
Stereo, 2 ohms: 1 x 1100 Watts
T.H.D. + Noise: <0.03% @ 4 ohms.
- Hand made in USA
-Total power output 1450 Watt
-Single Channel Class A/B Monaural Amplifier
-EHV High Voltage Output Circuitry
-Two Ohm Mono Stable
-Dynamic Bass Boost Port
-12 dB Variable Bass Boost Control
-Heavy Duty, High Current Terminal Blocks
-Compact Chassis Design
-Gate Drive Boost Circuitry
Item: ID MAX 10"” Sub
Price: $600
Extra Info:
Hand made in USA
Includes custom made sub box to suit ID Sub
Clean powdered off Zapco 1100.1 Mono-Block, includes custom box to suit XR5,
Item: Pioneer P7850 DVD/MP3/DIVX/MP4
Price: $950 (RRP was $4,000 ~)
Extra Info:
Made in Japan, complete with box, manual, remote control, Auto EQ Mic, Fascia case & I-Pod adaptor
Contact: 0429 999 886 or [email protected]
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
