Item: RE Audio XXX 6.5" components/splits
Item Condition: Brand New Condition (Used)
Reason for selling: Getting company car
Price: $500
Extra Info:
Complete with box/packaging as new,
Made in USA
Clean powdered by a Zapco 350.2 Amp
Impedance: 2 Ohms -
6.5" Midbass Driver with very high excursion
1" Silk Dome Tweeter
Power Handling: 150W RMS
Item: Zapco Ref 350 2-Channel Amplifier
Price: $700
Extra Info:
Hand made in USA
Complete with aluminum mounting brackets, box, manual, birth sheet. Including balanced Symbilink Cable & SLDIN SymbiLink Adapter. -No need for RCA’s
Stereo, 4 ohms: 2 x 100 Watts
Stereo, 2 ohms: 2 x 170 Watts
Bridged, 4 ohms: 1 x 330 Watts
T.H.D. + Noise: <0.025% @ 4 ohms.
- Hand made in USA
-Total power output 380 Watt
-SymbiLink™ Balanced Inputs
-RCA Unbalanced Inputs
-Two Ohm Stereo Stable
-18 dB Variable Bass Boost Control
-Built in Variable Electronic Crossover
-Bridgeable
-Three Channel Capable
-High Current Bipolar Outputs
-Optically Isolated MOSFET Power Supply”H
Item: Zapco Ref 1100.1 – Mono Block Amplifier
Price: $900
Extra Info:
Hand made in USA
Stereo, 4 ohms: 1 x 825 Watts
Stereo, 2 ohms: 1 x 1100 Watts
T.H.D. + Noise: <0.03% @ 4 ohms.
- Hand made in USA
-Total power output 1450 Watt
-Single Channel Class A/B Monaural Amplifier
-EHV High Voltage Output Circuitry
-Two Ohm Mono Stable
-Dynamic Bass Boost Port
-12 dB Variable Bass Boost Control
-Heavy Duty, High Current Terminal Blocks
-Compact Chassis Design
-Gate Drive Boost Circuitry
Item: ID MAX 10"” Sub
Price: $600
Extra Info:
Hand made in USA
Includes custom made sub box to suit ID Sub
Clean powdered off Zapco 1100.1 Mono-Block, includes custom box to suit XR5,
Item: Pioneer P7850 DVD/MP3/DIVX/MP4
Price: $950 (RRP was $4,000 ~)
Extra Info:
Made in Japan, complete with box, manual, remote control, Auto EQ Mic, Fascia case & I-Pod adaptor
Contact: 0429 999 886 or [email protected]
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
