My friend recently gave me his HKS SSQV III which was brand new, genuine. So I thought why not slap it on, I'm running a stock GTST Series1 turbo and I'm getting turbo flutter in the low RPMs, not so bad at high rpm though, at high RPM I can actually hear the bov not flutter. I'm venting to atmosphere too. The owner I bought it off did a dick move and decided to mechanically tune it to 14psi (I have no boost controller) which pisses me off because right now I don't have the money to buy a boost controller/take it to a mechanic.(is there a way I can drop it myself?)
Is this bad for my turbo? I google around and see too many mixed answers, hopefully I can get someone who experienced the same problems.
Thanks
EDIT: I'm not even sure if it's running 14 psi, I realised the stock turbo would not handle that at all, brb previous owner used shitty marketing tactics.
Edited by Jo33
https://www.sau.com.au/forums/topic/402872-opinions-on-turbo-flutter/
Put your stock bov back on and it will most likely fix whatever issue you have with flutter.
If its running more than stock boost there will be a boost controller of some description or a new wastegate actuator. Either way it's an easy fix to drop it back to stock.
Edited by Mitcho_7
I'm not fussed with the flutter, Just wondering will my turbo nuke itself over time due to the fluttering and if anyone gets fluttering with the stock turbo and hasn't ever had problems. I heard about mucking around with solanoids to change the boost but my guess now that it can't be running 14, my stock boost gauge isn't showing huge spikes in pressure etc etc and It definately doesn't feel 14psi when I put the foot down haha
And what exactly does 14psi feel like?
It could be running 14psi if the previous owner changed the actuator, as previously mentioned. The stock turbo can make more than 14psi, but it's a time-bomb waiting to go off and it will be way past its max flow anyway, so you won't be getting any gains. That said, if it still has a stock ECU then it would probably hit R&R before it makes 14psi.
Even if you don't have an EBC, I assume you have a bleed valve or turbotech type valve to be able to adjust the boost level? Borrow a gauge and check of your worried...
As for the Atmo BOV... Well they are not a
Popular item around here, so any problems caused by them are generally laughed at...
Put the stock BOV back on, the HKS sound actually gets annoying. My boost is 7psi, the previous owner was talking shit.
Also @ People calling me out, I got a free aftermarket blow off valve why not try it out, This query is directed more at turbo flutter than 'lyk bro how do i get a fully sik flutter wiv out da blow up ov my turbo cuz'? hence the title of the thread.
Because of the problems they can cause.
And now I learnt they are not worth the time and effort/money, also fair enough, I'm new to this forum/cars just getting general opinions, I'll go back to lurking
The guys have been pretty well behaved for a change, generally any mention of a BOV or Flutter goes to sh*t pretty quickly! At least you can now see that the BOV is a waste of time and continue to enjoy the car, with some of the questions you have asked it would be a top idea to get stuck into reading the info sections, DIY stuff and just general info on the forum, you will learn as you go! SAU is the place to be, just read, learn and enjoy :yes:
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
